Results 11 to 16 of 16
- May 2005
- 5
December 8th, 2005 11:04 AM #11sir, pasingit na rin po dahil similar problem ko. My ride also has clutch fan (na laging on) instead of electric fan. I had it "repacked". Lalo po umingay ngayon at lumakas sa gas. Humina rin po ang pulling power ng ride ko. Ano po kaya problem?
TIA
December 8th, 2005 11:24 AM #12
What do you mean by "repacked"? Yan ba yung dinagdagan/pinalitan mo lang ng silicon oil ang loob ng clutch fan? I would suggest you buy a new clutch fan. Nasubukan ko din yan dati and ganyan din nangyari. Palaging naka-engaged ang fan. Nasayang lang silicon oil ko
- May 2005
- 5
December 8th, 2005 11:51 AM #13silicon oil nga yung sir. 4 tubes ang nagamit. kailangan na daw kasi irepack to prevent overheating. super lamig din po ngayon ang aircon pero super ingay naman ang fan lalo na sa high rev
- May 2005
- 5
December 8th, 2005 01:48 PM #15gets ko na sir. kaya pala super ingay. Thanks a lot. Pano po kaya ang gagawin ko? baklas uli then bawas ng silicon oil?
- Dec 2005
- 7
December 10th, 2005 04:35 AM #16Originally Posted by deepblue
imagine, kung ilang ulit mo p gagawin ito 2 make ur formulation right...kalas ka ng belts ng aircon, fan and kung mamalasin pati powersteering pa! e2 pa, malamang kakalasin mo din ang fan cover or iiwan mo ung blade dun sa cover
para ma- pull out ang clutchfan... tideous d b?! kaya ang mekaniko tatamadin tlaga lalo na kung mainit ang engine pag dinala mo, paso!!! hehehe! either ipe-permanent nila ang clutchfan or papalitan n lng ng bago.
RWD with the heaviest part of the car -- the batteries -- in the back, just makes a lot of sense to...
Jmev ev2
