Results 1 to 7 of 7
Toyota is my choice
- Aug 2005
- 2,063
December 11th, 2005 03:54 PM #1mga sir.. unti na nmang tulong.. i found out na may unting leak or sugat sa top ng radiator ko.. akala ko dumi lng.. plastic yun radiator ko (orig) tapos sa top lng beside sa radiator cap ko.. napansin ko lang kanina kasi nag pa flush ako sa aking radiator.. pgkatpos sabay throttle ayun may unting lumabas na water na parang sugat.. tsk tsk... mukhang lalaki kpag hindi na agapan.. pero sabi daw yun taga petron is pwde daw lagyan ng epoxy????
ano po mas suggest nyo po? sealant na ayos pra sa unting leak?..
for the meantime lng po kasi wla pa sa isip ko bumili ng bagong radiator..
thank you and happy holidays!Last edited by finchy18; December 11th, 2005 at 08:23 PM.
December 11th, 2005 04:54 PM #2
based on experience, by the time na may nakita kang leak sa labas, malaki na leak nyan from within.
Pagawa mo nalang. If Denso ang OEM plastic radiator mo I suggest pagawa mo sa Denso... PM mo nalang si Zeagle.
Toyota is my choice
- Aug 2005
- 2,063
- Mar 2004
- 652
December 15th, 2005 12:46 AM #4bro, noong nagpapalit ako ng gulong sa servitek dimasalang, napansin ko na meron silang naka-ads na gumagawa (I mean, repair) sila ng plastic radiators. di ko lang masyado napagtu-unan nag pansin. try mo tawagan at inquire ka. again, the locale, "SERVITEK, DIMASALANG".
Toyota is my choice
- Aug 2005
- 2,063
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 16th, 2005 08:53 AM #6tama, once it starts leaking wala na yan. either have it repaired or buy a new one.
- Mar 2004
- 652
December 18th, 2005 12:19 AM #7Bro
Pasensiya ka na. di ko nakita location mo sa Cebu pala. Mistake ako
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
