Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
    Jul 2013
    #21
    Quote Originally Posted by Gian Paulo View Post
    May big boost effect ba sa AirCon if magpalagay ng auxcilliary fan sa Radiator front ? TIA.
    If you're stuck in traffic... Yes, the aircon condenser's fan is a big plus...
    But, of you're mostly travelling outside the city... You can live without the extra fan.
    #22
    i had an inline 4, rear wheel drive liftback before. installing an auxiliary fan in front of the radiator did wonders to my aircon woes, traffic and highway.
    today, all front wheel drives have aux fans in front of the radiator or aircon heat exchanger.
    what's your car, po? my guess is, an inline rear wheel drive?
    Feb 2009
    #23
    Quote Originally Posted by jodski View Post
    Mas mabilis lang lumamig kaysa dati.
    Pero kung ang habol mo is mas lalamig pa ang buga sa vent, ibang usapan na yan at mas magastos
    Sent via Tapatalk
    for discussion sake, if you can acquire a concentric low side hose (the inlet to the evaporator wrapped around by the outlet tube), the efficiency of the evaporator is increased. the remaining "cold" of the evaporator outlet tube is allowed to cool the inlet tube. this is similar to recycling the heat or cold. the incoming lower temperature liquid refrigerant temperature is allowed to cool down a bit so by the time it passes through the metering device (orifice tube or expansion valve) it is at an even lower temperature. this is currently done on hybrid and electric vehicles climate control
    Apr 2016
    #24
    Quote Originally Posted by eurostyle View Post
    Un sa akin sir pagka turn ng ignition key sa on position umiikot na siya.
    Naka rekta nga ung fan mo sir, Kinokontrol ng thermo switch yan nakalagay un sa line ng tubig papuntang radiator, pag mainit na ung tubig tsaka aandar fan. Madali madiskarga ung battery mo kc uma andar ung fan kahit di pa uma andar ung engine
Radiator fan
