Results 1 to 10 of 16
June 6th, 2017 07:01 PM #1
Mga sir may ilalakas pa po kaya ac ng van ko pag nag palit ako ng laminated condenser? Malamig naman po yung ac ko kahit tanghali nung pina check ko pomga 11am 3deg yung lamig nya naka #2 yung fan nung sinukat nila..
Ang prob mga sir eh pag tanghaling tapat at naibilad sa araw tapos naka idle eh hindi na mag aautomatic pag nasa 1/2 seting na thermostat kelangan ko nanamang babaan sa pinaka lowest setting ang prob naman mga sir pag nasa lowest seting naman termostat madali naman mag automatic mainit naman hehe lalo pag tumakbo na yung van panay na automatic kaya lalong iinit ... kaya pag nag palit kaya ako ng laminated na condenser baka bumaba pa ng zero deg yung buga nya kahit tanghali? Para kahit naka sagad na sana yung settings ng thermostat niya mag automatic pa din hehe nakaka pagod kasi pag panay ang adjust ko nasa baba paman din ng glove box yung termostat😂
Sent from my GT-I9301I using Tsikot Forums mobile appLast edited by sotel; June 6th, 2017 at 07:11 PM.
June 6th, 2017 07:04 PM #2
Btw mga sir ok naman yung mga aux fan ko para nga nagwawalis ng daan yung van ko lalo pag nadaan ako sa maalikabok na area😂
June 6th, 2017 09:43 PM #4
nasa thermostat settings lang iyan.
your settings dictates how/when your compressor will engage/disengage.
set mo "pababa/cooler side" ang thermostat para mas malamig ang cabin, mas mahaba ang interval ng on/off ng compressor.
- 54,286
June 6th, 2017 11:46 PM #5mas mabuti na yung nagwawalis.
kung baligtarin mo ang connections, ay hihigupin ng fan lahat ng basura sa daan.
sorry ka na lang na yung hinahanap mong lamig ay nasa pagitan ng dalawang settings. just learn to live with it, po. wala kayong magagawa. as bench says, set it to cooler, and enjoy the cold.
replace condenser?
if it is not the condenser's fault, replacing it won't solve the problem.
i used to have a van whose engine was under the driver.
the aircon wouldn't get too cold, as the engine heat was permeating easily into the cabin. also, i determined thru testing, that the long rubber weatherstrip of the sliding door wasn't closing airtight. some of the cold air was leaking out, and some of the warm air outside was leaking in.Last edited by dr. d; June 7th, 2017 at 12:41 AM.
- Oct 2009
- 2,271
June 8th, 2017 01:07 PM #6baka ung thermo switch mo ay ung manual at hindi electronics kaya ganyan.at baka conversion na ginawa dyan.baka dating electronic ung thermo niya at pinalitan ng manual..
- Jun 2008
- 1,741
June 8th, 2017 03:53 PM #7Anong sasakyan yan? Orig or modified ang AC component installation?
Sent from my NX549J using Tsikot Forums mobile app
June 8th, 2017 06:15 PM #9
Hyundai grace sir modified na ac change na ng dalawang condenser pro serpentine lang yung mga nakalagay na condenser tapos yung dual ac niya sa likod yung yokohama
June 8th, 2017 06:19 PM #10
ok naman na yung ilalim ng upuan nilagysn ko na ng insulator yung nilalagay sa bahay..
PV=nRT you know
