Results 1 to 5 of 5
    PLease Help, what type and where to buy fanbelt for my mazda 3 2005 2.0
    nakalagay kase 5pk555, can't find one on any near suto supply here in batangas
    what other alternative fanbelt types should I look for and where to buy?
    badly needed to replace na kase
    thanks!
    Sep 2012
    na try mo na ba sir tanggalin and bitbitin na lang yung belt para i compare? Sa Lipa dami mabibilhan nyan kahit bando na brand... basta exact ang dimensions there shouldn't be a problem
    Feb 2009
    Quote Originally Posted by mudspit View Post
    thanks!
    At the back of the belt, there should be a numerical code, e.g. 5PK1520; 5 for the number of grooves of the pulley and the 1520 the stretched length in centimeters
    thanks!
    If you could'nt find 5PK555 in your area you may substitute 5mm longer say 5PK560, usually the tensioneer allows more than 15mm adjusting limit. Most car stores don't carry those multi-grooved serpentine belts. Better check casa or auto shops in Manila/ Pasay area.
    thanks sa lahat ng nagreply, wala mahanap near dito, nag-paorder na ko sa isang auto supply pero mali pa rin naorder nung ikakabit na. wala rin daw tensioner yung pagkakabitan nung nicheck nila mazda 3 ko. wala kase near na mazda or ford casa dito so probably lumuwas na lang ako. thanks again
