Results 1 to 10 of 30
- Jan 2011
- 99
November 11th, 2014 10:49 PM #1Mga sir at expert jan may problema kotse ko d umiikot yung rad fn at a/c fan dinagdagan ng freon ng kaibgan ko tapos ang ginawa niya habang umaandar makina binuhusan ng tubig ung radfd fan at a/c fan tapos ayum ok naman umiikot sya like normal .. Tapos kinabukasan nung pag on ko ng aircon napansin ko d lumalamig yung a/c kahit naka high temp siya nung buksan ko yung hood nakita kond umiikot yung a/c fan at rad fan kahit naka on na yung aircon.. Ano kaya problema nito check ko na yung fuse ok naman lahat samantala bago dagdagan ng freon eh ok pa yung mga fan .. Sabi ng kaibgan ko baka daw may leak na kaya d umiikot paano ba maganda gawin dito paano ba basic troubleshoot ..?? O maganda pa check ko muna sa aircon shop.?? Thanks sa makakasagot
- 54,290
November 11th, 2014 10:55 PM #2just bring it to the aircon fixit shop, sir.
they'll trouble-shoot it faster than i can describe it here.
- Oct 2014
- 341
November 12th, 2014 12:40 AM #3Have it check in a shop sir. But my guess is napasukan siguro ng tubig yung fan motor kya di umiikot. Try to spin the fan blades with a screwdriver check mo kung aandar.
- Jan 2011
- 99
November 12th, 2014 10:23 AM #4Thank mga sir sa quick response niyo ... Dko pa nadadala sa a//c shop balak ko palang ipacheck...
About naman dun sa paikutin yung fan is gumana siya sir kaya lang after a few seconds d na ulet umikot at until now kahit paikutin mo ayaw na gumana.... Ano kaya posible cause d kaya dahil sa pagkakabuhos ng tubig habang umiikot yung fan .??
November 12th, 2014 12:18 PM #5
most probably, sira na yung motor ng radiator fan.
matigas na yan.... parang household electric fan na bumara ang alikabok sa motor and ayaw ng umikot.Last edited by 1D4LV; November 12th, 2014 at 12:29 PM.
November 12th, 2014 12:25 PM #6
Just replace your fan motor. Yun ang sira nyan. Depende sa auto, it could range from 3k to 6k, band new.
November 12th, 2014 12:57 PM #7
to eliminate the possibility of the motor being the cause, try connecting the motor using a fused jumper to the battery and ground. if the motor runs, the trouble could be of the wiring, controls, relays or maybe even the pressure switches since you mentioned you just had the air conditioner repaired.
November 12th, 2014 01:00 PM #8
dats korek better pa tsek mona yan bro sa aicon technician, alam na niya ang gagawin diyan para ma tsek na niya lahat, hindi kaba nataas ang temp gauge mo pag nag oopen ka ng erkon lalo kamu at di nagana fan niyan..
- May 2014
- 72
November 12th, 2014 01:25 PM #9
- 54,290
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
