Kapag traffic or low speed Ok ang lamig ng aircon. kapag umandar na kotse ng mga more than 60kph, biglang iinit. pag huminto na naman ang kotse, madidinig mo gagana na yung compressor and lalamig na ulit. Ok naman freon levels, bagong linis din condenser, evaporator, fans, and malakas naman yung condenser fan. hindi ko naman madinig kung nag-sli-slide yung clutch hub kasi tumatakbo sasakyan. 96 civic ang kotse. Parang baligtad di ba? but it actually happenned kangina lang habang kainitan ng araw sa edsa. any inputs?
1. Defective electronic control - Pag Wide Open Throttle (WOT) like when you are accelerating, the ECU will disengage the aircon compressor clutch temporarily.
2. Defective High Pressure cut-off swith ng aircon system- cut din kasi nito current sa aircon compressor clutch pag sobra pressure sa aircon system.
3. Di kaya overcharged ang refrigerant mo - wild and idiot's guess lang.
assuming ecu is okay when WOT, you may consider also the grounding of engine where the comp is attached, it might loosen during at high rpm. it happend to me. Better check, baka poor ang grounding ng engine
Mukhang unburnished clutch hub/pulley ang problema. mukhang nagsli-slide nga siya during high speed hindi ko lang naririnig. I tried burnishing by turning the AC on and off every 4 seconds about 50 times. na solve ang problema hehehe. thanks for the input guys. sobrang weird ng lang ng experience na to
Maalala ko, sabi nga pala ng tekno sa casa, usually ang mga problemang ganito are more on the the "connection, mechanical, or actuator' side ng computerized vehicles. Yung Computer daw ng car is build to last, meron itong back-up computer para kahit paano ay tatakbo pa rin ito kahit may major problem yung main computer.
Meron din itong RAM to adjust with the changing conditions while you are driving.
nangyari sakin yan pero baliktad pag umaandar doon nag gagana ang compressor tapos pag stop tigil tapos rining mo na hirap siya mag start ang compressor nakita problem ko is aux fan kasi pag andar may hangin na pasok kaya ikot siya pag tigil wala na. Madali lang ayusin yan baka connection lang
