Results 1 to 10 of 19
    May 2004
    I will choose surplus original... or if budget permits Original brandnew... the plastic top radiator have its purpose... its like your cooling system's fuse...
    Jun 2011
    Quote Originally Posted by 1997 View Post
    why sir? pls. elaborate.....
    ang alam ko kasi sir, if nag overheat, unang bibigay yung plastic top. if metal top na, CH na agad bibigay.
    Jul 2006
    Id get the aluminum aftermarket if the budget would allow it.
    wag lang yung sobrang laki na masyado from stock specs ha.
    Aug 2005
    Quote Originally Posted by dumschmuck View Post
    What if you can get a radiator that drops in and gives up up to 3x the performance?
    Jun 2011
    sir dba ang unang bibigay or lalabas ang water eh sa rad. cap...
    then sir before pa bumigay yung plastic, yung pangdikit or yung water sealant muna ang unang bibigay..
    AFAIK iisa lang naman ang gamit nilang sealant or pandikit dun....
    IMO maplastic or aluminum or copper may required min. and max. PSI din po yun...
    Aug 2005
    The "fuse" is your radiator cap and your overflow to the reservoir.
Question:  How much more will you pay?
