Results 1 to 20 of 26
    Feb 2012
    mga sir bakit kaya yung liteace ko di masyado maka ikot yung compressor tapos nag slide pa belt bago naman po ung belt, sagad nman na po pagka adjust ng belt
    Jun 2011
    baka kelangan papalitan bearing....
    Quote Originally Posted by sotel View Post
    compressor problem malamang. kung gagananciahin, replace bearing lang. kung mamalasin, throw and replace compressor..
    Feb 2012
    mga sir kung papalitan poba ng bearing dina tatanggalin freon?
    nasa creativity na yan ng mekanikong gagawa. kung dapat i-baba at i-disconnect ang rubber hoses sa compressor, ay tatanggalin nga ang freon. ngunit kung kaya naman ng mekanikong palitan ang bearing nang hindi i-disconnect ang mga rubber hose, ay hindi ka mawawalan ng freon.
    hindi ko masyadong alam yan, dahil sa karanasan ko, ay throw away lahat ang mga compressor na nasira sakin..
    Oct 2011
    pa check and troubleshoot mo na lang sa qualified mechanic.
    Feb 2012
    mga nsir wla nmn tagas na langis sa compressor. sabi kasi saken pag may tagas sira nna daw bearing
    ung tensioner mga sir may alog onti
    Two potential cause of your problem.
    - compressor bearing itself is worn out and causing the shaft to get stuck.
    - AC freon filter is clogged and needs replacing.
    Usually its the first problem but it can't hurt to check the 2nd potential cause first because it's easy to check and cheaper to replace a clogged filter too.
    compressor bearing yan bro... napapalitan yan.
    sabay mo na cleaning.
    Feb 2012
    kakatapos lang magpalinis a/c nung april mga sir
    Jun 2011
    or, pa-check mo baka natuyuan na capillary oil...para sure
    Feb 2012
    mga sir nilagyan ko ng asphalt ung belt dina nag slide gumana na uli a/c ko.
    ano kaya ang sira mga sir?
    baka naman luma na yung ac belt?
    sa akin, mas ok pa din palitan yan... baka maputol eh.
    Feb 2009
    Quote Originally Posted by dnomyar View Post
    never heard of capillary oil being used in cars, maybe you are referring to capella oil used in refrigeration or ice makers.
    Bossing,
    Most likely its a bearing or other mechanical compressor failure. Better have it repaired immediately as it might cause more damage to your compressor as well as other connected parts. Usually, the freon has to be removed as the compressor has two bearings located at both ends. Better have it estimated (after dismantling) so you may have an idea if its more feasible to repair or replace.
    Cheers!
help di masyado maka ikot compressor
