Results 1 to 16 of 16
    Apr 2009
    ano magandang coolant? mas ok po ba yung no need to add water? I always see this prestone coolant sa mga stores. baka may iba pang mas ok.
    Mar 2005
    Gamit ko yung Peak Long Life Coolant concentrate. Sa Label niya 5 year or 150,000 miles. Php.1.2++ yung 1 gallon niya. Meron sa True Value or Handyman. Make sure lang to use distilled water pang dilute sakanya.
    Prestone should be good enough. Meron din silang pre-mixed na in gallon jugs. No need to add water.
    Apr 2015
    Try Pro99. Had it used sa Ford lynx ko. No problems naman. As long as tama yung timpla. 50-50.
    i use any brand, as long as the liquid is of the same color as mine.
    Just get the pre-mixed type para wala ng hula-hula
    Oct 2009
    I've been using Prestone for the longest time. Wala namang naging problema sa naging mga sasakyan namin.
    Apr 2009
    how many liters ba kelangan ilagay sa radiator lets say if im going to use the pre mix coolant?
    Apr 2009
    that depends on what car you have. I use toyota OEM coolant in my car
    Aug 2012
    Quote Originally Posted by bail View Post
    Depends sa size ng radiator. Nakalagay sa user manual kung ilan liters ng coolant ang kailangan ng kotse mo. Example, 4.6L for Toyota Yaris. This means you need 4.6L pre-mixed coolant.
    ano nga ba kulay ng pre-mixed prestone coolant mga kapatid?
    Apr 2009
    ^ consult mo na lang manual mo. i'm sure naka-indicate doon ang coolant capacity/amount required ng cooling system mo bro
    same lang naman ang # of liters na gagamitin whether you use the premixed variety or the 50/50 one
    Toyota super long life coolant. Gamit ko of corz sa vioski ko, ek at iba pang dasakyan. 300 petot per bottle (2 liters) good for 80k kms before replacement. So pagkadrain mo depende sa sasakyan, mga 2 bottles (4 liters) more or less lang need mo.
    No need to dilute.
    Aug 2012
    Toyota Super Long Life Coolant din ang gamit ko. P300+ per 2 liter bottle. Nagtanong ako dati sa store ng Prestone 50/50 Premix Coolant, P600+ per 3 liter bottle. So mas mura yung Toyota Super LLC. For P600+, may 4 liters na ko.
    Jun 2011
    Antifreeze - Wikipedia, the free encyclopedia
    http://en.wikipedia.org/wiki/Antifreeze
please recommend a coolant
