Results 1 to 12 of 12
    Feb 2006
    mga sir gud pm po,
    tanong lang po :
    if i were travelling then nagoverheat yung ride ko , what should i do?
    do i turn off the engine and wait for the radiator to cool a little bit (just enough so i can open it without splashing boiling water to my face)and directly add water to my radiator while my engine is OFF or Running/ON??
    sbi po kc dati s kin ng isang mech n dapat daw pag nagdadagdag ng tubig especially if the engine is HOT / overheated dapat daw i add water while my engine is running so as to prevent the head from warping.
    tama po b yung tip n to?
    salamat po sa mga inputs
    Bro,
    What I did when my previous car overheated was to open the hood, place a towel on the radiator and pour water until I was comfortable opening the cap. Once the cap has been opened I topped up my radiator with distilled water. I did all of this without turning my engine off. The reason (per my mechanic and my other auto owning friends) is that I may risk further damage to the engine by immediately shutting it off when it overheats.
    Thanks and God speed.
  3. #3
    kung di agad-agad tumataas, wag mo patayin, hayaan mo lumamig siya ng kusa sa tabi....
    dont open the cap immediately--mamainit pa sa pinakulo mong tubig yung tatapon..
    In my opinion shutting down the engine in an overheating situation will depend if you are already hearing mechanical noises or katok. This will save the engine from further damage. Dont attempt to restart let it cool down and if you want fill it up with water but call for a tow.
    But in a simple overheating problem shutting down the engine will create an after boil that could increase the water/vapor pressure inside the head and block because of the stop in the water pump circulation. The vapor is what really expands and dangerous. Let it idle before releasing the vapor but never fully open the rad cap.
    Feb 2006
    maraming slamat po sa mga inputs sir,
    blalk ko n n ga po palinis yung radiator ko e kc d k sure kung nkakaikot p coolant ko sa engine e!
    bale add coolant while the engine is still running right?
    any idea po nga pala if how much is cleaning /overhauling the radiator?
    tska about po sa water pump ng ride ko any idea if any telltale signs kung me problem n?pag pnalitan po ba yun e magkano inaabot?estimate figure lang po sana
    ride po pala is Galant 7G
    salamat po talaga ng marami mga sirs
  6. #6
    nope! antayin mo muna lumamig bago mo buksan ang cap..
Overheating Tips?
