Results 11 to 18 of 18
April 20th, 2006 03:55 PM #11
try to check your oil levels too. yan ang nangyari sa akin. mabilis tumaas nag overheat pa ako. yun pala kulang na sa lubrication engine ko kaya umiinit agad malamang sa friction galing
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 21st, 2006 12:33 AM #12you might have a hard time finding a service manual for the esi. problem is, the esi released in the philippines didn't have the same engine found in the esi's in the US or in japan. we got the 1.6 non vtec while the others got vtec equipped engines. so not all engine infor will be applicable.
- Apr 2006
- 40
April 21st, 2006 01:20 AM #13..thanks all..
got a new problem...my engine wont start now...i already filled in wiht gas and it wont still start...
i saw a red mark of a something like oil(like a genie bottle with oil droplet something...)
but i just filled it with engine oil 2 days ago...
please help again...
- Apr 2006
- 40
April 21st, 2006 01:20 AM #14..thanks all..
got a new problem...my engine wont start now...i already filled in wiht gas and it wont still start...the battery is fine though
April 21st, 2006 12:04 PM #15
mazerom; medyo nasubaybayan ko yung mga thread mo lalo na nung hanap ka car. di ka ba nagsama ng mekaniko nung kuha mo kotse? pag umandar yung kotse better pa compression test mo na rin.
April 21st, 2006 09:59 PM #16
I am having problem with my Toyota liteace 92 model,balak ko sna pa upgrade in to 3 rows radiator ko because of over heating. pero napansin ko lang na hindi bumabalik ung tubig from reservoir to radiator after gamitin. Usually dpat pag iniwan mo ng overnyt mababawasan ang reservoir dba? pero chk ko ung reservoir halos umapaw den chk ko ung sa radiator almost haf liter ang nilagay ko.So nag dadalwang isip ako papalitan radiator ko into 3 rows kc bka ganun pa rin problem. Anybody pls help
pls reply.
- Nov 2003
- 3,848
April 22nd, 2006 06:05 AM #18yeah agree. it's easy to point you in one direction or another but unless makita yung exact symptoms it might be useless
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
