Results 11 to 20 of 21
- Jun 2007
- 15
January 7th, 2008 11:53 AM #12
- Jul 2006
- 145
January 9th, 2008 08:46 AM #13carlo, yun munang pinaka simple ang ipacheck mo. may leak yan panigurado.
1. radiator hoses
2. water pump area
3. leak sa mismong radiator, yung mga cap, yung plug sa ilalim.
wala bang nakitang leak sa mga yan?
January 9th, 2008 09:18 AM #14
Do you put coolant additive?
Did you check belts? Water pump?
Check water level in the morning and again in the next morning, observe.
To check for leaks, in the evening after a days run put newspaper under the radiator and w.pump area and leave it. In the morning check for stains.
Avoid cavitation or air pockets in the system, this spots will heat up the engine rapidly.Last edited by 4JGtootsie; January 9th, 2008 at 09:22 AM.
- Sep 2006
- 1,335
- May 2007
- 6
January 12th, 2008 02:19 PM #16my problem is like this, i have honda esi 93. plague ako nag overheat so dinala ko sa ibat ibang mekaniko para pa check sabi nila me problema daw sa engine kc natigas yung mga hose at nag build up yung pressure which is true, kc nung pinalitan ko yung radiator bigla nalng me sumingaw galing engine, nagpapalit din ako ng thermoswitch.kala ko ok na pero ganun pdin walang pinagbago, nakulo yung radiator ko at ang bilis tumaas ng temp, sabi ng nag check ng car ko na ang problema daw ay BHG na, so i said sige pagawa ko na,and to make the long story short ginawa na sya, pero i still have the same problem, nataas padin sya pero di na gaya ng dati,di na naabot sa red, at pag wala a/c sa gitna lng sya up and down yung sa thermo guage..ang tanong ko lng, is this normal pag nabuksan na ang engine, di nba sya babalik sa dati nya na naka pirmi sa gitna yung temp? or should i consider change of engine? sabi kc skin na once na nag overheat na ang honda might as well buy a new engine kc sakit nlang ng ulo ang mangyayari? pls help....
..change thermo switch
..change radiator
..top overhaul and fix BHG
macky
January 12th, 2008 03:51 PM #17
hey bro, did they even "purge" or bleed the cooling system?? also, did they replace the Thermostat?? kasi posibleng may air pa na trap sa loob ng coolinh system and the air needs to be bled out. also, nung ginawa ba nila yung Head Gasket replacement, did they re-surface (or re-built) the Cylinder Head?? like did they do a complete Valve Job, etc?
aite, peace.
- Sep 2006
- 1,335
January 12th, 2008 05:53 PM #18
- Jan 2008
- 26
January 16th, 2008 02:35 PM #19sir nacheck nyo na po ba kng properly working yung radiator fan nyo???kng may leak ung radiator???ksi ako dati nagoverheat din auto ko....and the main reason is ung motor nung radiator fan ko nasira...sabi skn sa servitek pati yung thermal switch din not properly working na kaya pnalitan ko din.
- May 2007
- 6
January 17th, 2008 04:10 PM #20oo, pinamachine shop nila..so ginawa ko nlng to fix the issue is nag lagay ako ng aux fan na sabay sa a/c so far so good ok naman sya, pero nakulo pdin..any shop na pwede nyo recommed para ma fix yung problema ko ng tuluyan? im from bacoor cavite..tnx
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
