Results 1 to 3 of 3
    Feb 2006
    Mga sir ,
    Tanong ko lang po__
    PAg po ba naoverheat kyo sa daan ?how do you refill the water in your radiator?do i fill it with the water with the motor running still hot ?OR do i turn OFF the engine and fill it with water and then turn it on after i refill the radiator?
    tska napansin ko po na pag patay aircon k e di umaandar yung fan both the main fan and the auxilliary fan but after i turn it on the a/c both are working ,di po ba dapat by the time na start ko engine dapat ON kaagad main fan d po b?
    maraming salamt po sa mga replies
  2. #2
    never open a hot radiator with your bare hands! especially while the engine is running! kung di di lang 2nd-degree burns makukuha mo, major injuries pa kasi pressurized yan-->imagine open a shaken unopened cola bottle,diba tatapon, now gawin mong 100+degress C yan...
    the proper and the long way is palamigin mo muna! then buksan mo-->kung sa gas station ka,tubigan mo ang radiator until it cools down.
    patayin mo ang makina pag malamig na, try to use your long tire wrench or pang angat ng jack to gently open the cap(kung walang button to realease the pressure of the system built in the cap), slowly pag nag loos na, hanatayin mo munang sumingaw.. pag wala nang singaw alisin mo na ang cap ang refill it na with water...
    nope, main fan shoul run only kung naka-abot na yung preset temp ng temp sensor(kung stock system), pwede mo ding derecho or always on, pero madali masisira ang fan mo...
    ganun talaga pag buhay a/c buhay ang fan-->condenser reasons naman kasi,e..
    Nov 2003
    never shock the engine by putting in water to an overheated engine. always allow it to cool down muna or else it will warp for sure.
Overheat Question?
