Results 1 to 5 of 5
    Jul 2011
    i have tried riding along with so many a/c cars/vans/buses but nvr did i encounter na na amoy ko outside environment like pag passing trough a canal or dump site ng mga basura.. yan problem ng auto ko ngayun, present problem ng very first auto ko although 3rd owned na ako.. tnx tsikoteers!!
    Jan 2010
    Quote Originally Posted by poochie02 View Post
    try checking the fresh air/recirculate blend doors. the cable operating this is just held by a clip also used to set an adjustment. the cable might have fallen off or the cable is misadjusted
    usual problem ng old cars, baka sira na yun mga foams sa paligid ng butas, next time ,ag pa A/C cleaning ka pa shut off mo na permanently.
    Jul 2011
    *barako ba ma
    tnx sa info but i think the cable is in place pa nmn..
    *shadow
    yup its a 1997 model seadan, what do u mean shut off permanently?
    Feb 2009
    *barako ba ma
    *shadow
    what the shadow is saying is to lock the shutter control to fresh air mode. before you do this, make sure you replace the foam seal at the blend door lip. a good substitute for the worn out foam seal is a window sill strip you can purchase from ace hardware. in this case, you don't have to seal it shut anymore
(outside odor/smell problem) sa aircon?? whats wrong?
