Results 1 to 20 of 22
    Oct 2007
    Hey mga bro patulong naman, mag papa drain kasi ako ng radiator this week, I just want to know kung ilang "coolant at distilled wate"r ba ang kakailananin ko? may nakita ako sa ACE na Prestone Coolant 1Liter - 313 petot, Ok na ba ang 1liter? kasi sa mga nabasa ko dapat 50/50 dapat ang mixture. ibig sabihin ba nito kung 3 liters ang distilled water 3 liters din ang coolant? patulong naman po. naguguluhan na ako...di ko alam kasi kung gano karami bibilin kong coolant at distilled water. thanks
    May 2007
    Quote Originally Posted by lancer_89 View Post
    Correct: 50% coolant/ 50% distilled water. How many liters? Depende sa laki ng radiator mo.
    Dec 2007
    akala ko ung coolant basta ibuhos na lang dun sa plastic na lalagyan nya sa tabi nung radiator, ok na. may mixture percentage pa pala
    get the premixed na so you would not worry about the 50:50 ratio. imho, yung prestone is premixed na so buhos na lang yun.
    Jan 2008
    ilang beses po nagpapa-drain o nagpapalit ng radiator coolant sa loob ng isang taon?
    Quote Originally Posted by sarceangel View Post
    it should be at least once a year.
    Dec 2007
    Quote Originally Posted by 1D4LV View Post
    ahh i see, thats good to know. thanks!
    i'm still guilty of using regular tap water rather than distilled water. ung mga binibili ko kasi wilkins para sa gatas ng baby ko, baka magalit si misis pag sa tsikot ko nilagay hahaha peace
    Quote Originally Posted by jayemkay View Post
    Get the 5 or 6 liter container of Absolute distilled drinking water, it’s cheaper.
    TS, if you will use the concentrate, pour a liter or 500ml coolant then followed by the same volume of distilled water hanggang mapuno. prepare at least 2 liters of concentrated coolant at least. sobra na yun.
    Jun 2004
    pag premixed ba pwede ilagay dun sa container ng coolant? kasi sa sasakyan namin nasa minimum level na yun coolant resevoir. eh may stock dito sa bahay ng prestone.
    mejo nalilito din ako
    the answer is yes.
    Aug 2007
    Mga Sir, ibig sabihin bawal pala lagyan ng tap water ang 'coolant reservoir', dapat coolant talaga like Prestone ready mix?
Radiatior Coolant Question
