Results 1 to 8 of 8
    Sep 2009
    Hi po I'm new here at Tsikot....
    This problems happened to my Car all at the same time yesterday ....My car is Honda LXI 01
    Please Help po!!!
    1. Umaandar and blower ng aircon pero walang lamig (compressor di umaandar)
    2. Nawala ang power lock (central) pero ok ang power windows.
    3. Palagi naka ilaw handbrake indicator kahit na nakababa na.
    What do u think po ang problem?
    Napacheck ko na po sa dalawang good Auto Aircon Electrical shop (Rey's Auto Marikina at RAE Auto) di talaga ma solve ang problem. na try na din nila i recta umaandar naman lahat ng unit, walang problema sa compressor etc... sabi nila walang problema sa aircon unit
    They;ve check all fuse etc..... ok naman lahat kapag naka direct ay umaandar naman ang aircon. mukhang ang problem daw ay sa ECU or Computer box
    After almost 4 hours of analyzing walang nangyari....
    They referred me na to bring my Car to Honda Casa kasi nga daw mukhang computer box na ang problem..
    Help naman po baka may experience kayo na ganito ang problema na sabay sabay ang sira.....
    Thanks...
    1. well, you can bring it to Honda casa to have it diagnosed (but you will have to pay diagnostics fee)
    2. maybe the controller itself is broken?
    3. either low brake fluid or the rear brakes need adjustment.
    Sep 2009
    Thanks for the reply ghosthunter
    1. Opo mamaya nga ipapadiagnose and analyze ko na lang sa Honda Marikina (mga magkano kaya diagnostic fee?)
    2. Na check din po yung brake fluid, rear brakes etc ok naman
    3. Ang nakakapagtaka kasi ay sabay sabay nasira
    4. Do you think related ang mga sira... baka nga sa ECU na?
    Thanks sana maayos...
    Feb 2009
    Quote Originally Posted by jerompot2002 View Post
    jerompot2002,
    check the expendable sacrificial parts first. i would go for the fuses and the fusible links or autolink fuses(pacific fuses). these parts sometimes break open from overload because these sacrificial components get corroded and reduce their current carrying capacity. the autolink fuses are usually located near the positive battery terminals. contrary to most peoples' wrong guesses, stay away from blaming the ecu or ecm or pcm. like they always say, "if there is something wrong, blame the computer", not necessarily, check the inputs first. the computers gives you garbage output if your inputs are garbage in the first place.
    jick
    proper procedure jan scan for any codes muna and then monitor the live data then go with electrical schematic iagram
    sa dealer lang ata capable para ma perform ng ganito.
    Sep 2009
    thanks guys for the reply
    i went to Honda this am.ab... and they found the problem... pina analyze ko muna sa kanila.... Fuse box nga ang problema at hindi yung Computer box.... kaya sabay sabay pag bug down ng aircon compressor, power door ang windows, mga ilaw na di dapat umilaw, etc... Di na kaya ma repair ang fuse box.. kaya need na complete replacement.... Quote nila at Php 16,000.00 without labor... Haay ang mahal talaga sa Casa..
    Sep 2009
    i went to Honda this am... and they found the problem... pina analyze ko muna sa kanila.... Fuse box nga ang problema at hindi yung Computer box.... kaya sabay sabay pag bug down ng aircon compressor, power door ang windows, mga ilaw na di dapat umilaw, etc... Di na kaya ma repair ang fuse box.. kaya need na complete replacement daw.... Quote nila at Php 16,000.00 without labor... Haay ang mahal talaga sa Casa..
    what do you think?
Car Aircon, Power Door Locks and Handbrakes
