Results 1 to 5 of 5
- Jul 2011
- 27
August 28th, 2011 11:55 PM #1i have tried riding along with so many a/c cars/vans/buses but nvr did i encounter na na amoy ko outside environment like pag passing trough a canal or dump site ng mga basura.. yan problem ng auto ko ngayun, present problem ng very first auto ko although 3rd owned na ako.. tnx tsikoteers!!
- Jan 2010
- 283
September 5th, 2011 03:22 PM #2
September 5th, 2011 03:28 PM #3
usual problem ng old cars, baka sira na yun mga foams sa paligid ng butas, next time ,ag pa A/C cleaning ka pa shut off mo na permanently.
- Jul 2011
- 27
September 6th, 2011 09:45 AM #4*barako ba ma
tnx sa info but i think the cable is in place pa nmn..
*shadow
yup its a 1997 model seadan, what do u mean shut off permanently?
September 6th, 2011 04:20 PM #5
what the shadow is saying is to lock the shutter control to fresh air mode. before you do this, make sure you replace the foam seal at the blend door lip. a good substitute for the worn out foam seal is a window sill strip you can purchase from ace hardware. in this case, you don't have to seal it shut anymore
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
