Results 1 to 8 of 8
    Feb 2004
    My paraan ba para mas maaga madetect na magooverheat na yung makina? Ano ba additional protection mechanism na maiinstall para bago pa man umabot ng 3/4 yung temp gauge e, may alarm na? May sensor ba na ganun at paano iniinstall?
    Quote Originally Posted by xfreemanx View Post
    You can have an aftermarket water temperature gauge installed in your car. The factory gauge is not accurate and would only tell you if the cooling system is working or not. It doesn't tell you what temperature the engine is at the moment.
    Feb 2004
    San makakabili nito sir? Magkano isa?
    Auto Accessory stores.
    Make sure to check if the gauge will work with existing sensor OR choose a temp gauge with it's own temp sensor. Prices will vary greatly based on brand so better canvass first before buying.
    Nov 2003
    the best way to keep everything in tiptop condition is replacing parts periodically like hoses, thermostats, etc before they get busted.
    also use coolant so there's less rust buildup.
    Sa Concorde, baka meron
    when is the thermostat due for replacement? mileage? years?
    Jan 2009
    Or if your car has an under-dash OBD-2 DLC, you can spend about P7k and get more readings/measurements in one box using the ScanGaugeII (SGII).
    That's what I did: The "cWT" label is the Water Temp in Celsius
    [ame="http://www.youtube.com/watch?v=5YRNPHuQMps"]YouTube - ScanGaugeII on my 8th Gen Civic FD[/ame]
    [ame="http://www.youtube.com/watch?v=vDQb15wQxv0"]YouTube - Digital gauges on ScanGaugeII[/ame]
    More about the SGII here: www.scangauge.com
Extra and early protection against overheating?
