Results 1 to 10 of 20
September 3rd, 2017 10:15 AM #1
Meron ka na ba pinagawa prior to this incident?
Or first time ito nangyari?
Sent from my ASUS ZenFone 4 using Tapatalk
- May 2011
- 481
September 3rd, 2017 10:45 AM #2Use gauges, numbers are numbers regardless you're Korean, Japanese, Dutch, German or Mexican. Calibrated gauges don't lie.
Check the system voltage with the engine running at the battery terminals. Then check the voltage at the blower motor connector or terminals. The voltage should not be lower than 0.1 volt below source voltage while under load. If it is lower than source voltage minus 0.1, correct the voltage drop first. If the voltage falls within ball park figure, check the air flow or restrictions.
September 3rd, 2017 11:45 AM #3
Baka kulang na ng supply ng kuryente aircon motor mo.... or kulang sa ground... rekta mo muna to check...
- Apr 2015
- 12
September 3rd, 2017 01:16 PM #4nakuha ko ito sasakyan 2 yrs ago.. last feb nagpalinis lng ako and freon.. wala nmn repair or replacement ng parts..
September 3rd, 2017 02:03 PM #5
- Apr 2015
- 12
September 3rd, 2017 05:44 PM #7
Madami na binigay na recommendations above, take note of that para may basis ka.
Have it checked sa aircon shop. The unit is almost 17 year old madami na need i double check once na mapagalaw mo yan.
Didn't they recommend to replace the filter drier and expansion valve nung pinalinis mo?
Yan kasing 2 part na yan ng a.c., although optional na palitan, madalas pinagsisimulan ng problem kapag hindi pinalitan ng sabay kapag nagpabaklas ka.
September 3rd, 2017 05:56 PM #8
Cleaning madalas gawin pag mahina buga ng hangin, either madumi, barado kaya nagyeyelo, happened to me kaya nung napalinis na ok na ulit ang buga.
September 3rd, 2017 06:16 PM #9
- May 2011
- 481
September 3rd, 2017 06:29 PM #10The question is about air flow or air discharge delivery.
The air velocity and volume is also affected by cabin pressure. Is the symptom the same whether the doors are open or closed?
The air discharge flows from the evaporator then to the heater. If either is clogged or restricted the discharge will be weak and if the refrigeration function is working okay, the evaporator freezes up and the symptom gets worse. At high blower speed the discharge air should be strong enough to blow your one hundred peso bill or other paper money away.
Are they on track to surpass last year's sales?
Car Sales Data (2025)
