Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Apr 2015
    Title : Mahina buga ng fan/aircon
    Car: Honda Civic 1999
    Problem: Newbie lng po. Ano po pwedeng gawin kung mahina buga o labas ng hangin ng fan o aircon.. may lamig nmn pero parang mahina lang.. salamat guys..
    Quote Originally Posted by wsmolleno View Post
    the last time this happened to my (non-honda) car, it was because someone installed a wrong-type replacement evaporator.
    medyo malamig ang hangin, but still "hilaw". and because the evaporator iced up, pahina nang pahina ang buga ng hangin.
    replacing the evaporator with the correct one, restored everything to factory spec.
    Mar 2012
    I'm not familiar with your vehicle but the principle sa lahat ng sasakyan is similar. If may cabin filter ka check mo yun baka marumi and barado na. If walang cabin filter then probably barado or marumi na evaporator fins ng aircon mo. Pwede din mag cause ng low air volume ang marumi fan blower or mafunction ng air damper sa aircon duct na hindi naka full open. Those are only some of the causes but not limited dun sa mga binangit ko.
    Sep 2012
    Meron ka na ba pinagawa prior to this incident?
    Or first time ito nangyari?
    Sent from my ASUS ZenFone 4 using Tapatalk
    May 2011
    Use gauges, numbers are numbers regardless you're Korean, Japanese, Dutch, German or Mexican. Calibrated gauges don't lie.
    Check the system voltage with the engine running at the battery terminals. Then check the voltage at the blower motor connector or terminals. The voltage should not be lower than 0.1 volt below source voltage while under load. If it is lower than source voltage minus 0.1, correct the voltage drop first. If the voltage falls within ball park figure, check the air flow or restrictions.
    Jun 2011
    Baka kulang na ng supply ng kuryente aircon motor mo.... or kulang sa ground... rekta mo muna to check...
    Apr 2015
    Quote Originally Posted by jodski View Post
    nakuha ko ito sasakyan 2 yrs ago.. last feb nagpalinis lng ako and freon.. wala nmn repair or replacement ng parts..
    Sep 2012
    Binaba ba yung evaporator nung pinalinis mo?
    Apr 2015
    yes
    Sep 2012
    yes
    Madami na binigay na recommendations above, take note of that para may basis ka.
    Have it checked sa aircon shop. The unit is almost 17 year old madami na need i double check once na mapagalaw mo yan.
    Didn't they recommend to replace the filter drier and expansion valve nung pinalinis mo?
    Yan kasing 2 part na yan ng a.c., although optional na palitan, madalas pinagsisimulan ng problem kapag hindi pinalitan ng sabay kapag nagpabaklas ka.
Mahina Buga ng Aircon
