Results 1 to 5 of 5
    Good Day. Ask ko alin sa tatlong brand ng Coolant ang ok. Top1, Abro of Prestone Coolant? My Ride is 2011 Honda CRV 2.0V. Thanks!
    Jan 2009
    Quote Originally Posted by drich_enriquez View Post
    Honda Type 2, the best. If unavailable, Honda Type 1.
    Stick to OEM. It's not much more expensive than aftermarket, but the peace of mind is priceless.
    Something will happen kapag nag lagay ako ng ibang coolant no?
    Jan 2009
    Not saying that it will, but there's always that possibility. Again, if you want the guesswork out, use OEM.
    Old article. I can no longer find the source, but I beleive this was part of a service bulletin released to Honda dealers in the US (Honda) and Canada (Acura) several years ago.
    Genuine Honda Coolant is the Only Way to Go
    Increasingly severe operating conditions and the advent of lower maintenance requirements have resulted in significant changes in the variety and the concentration of additives used in engine coolant. Also, the continual improvements in engine and vehicle design have challenged coolant suppliers to design products that perform well in a more demanding environment.
    To meet these needs, Honda engineers have developed a superior, high-quality coolant that has several advantages over the competition.
    Some antifreeze, although labeled as safe for aluminum parts, may not be compatible with Acura cooling system components. Extensive research and testing by both Honda R&D and CCI, the manufacturer of the Honda coolant, have proven that the abrasive silicates and/or borates found in most domestic coolants can cause these problems:
    - - Silicates bond to the surface of the water pump seal and act as an abrasive, causing considerable seal erosion and coolant leakage. In actual tests, the silicated coolant caused early leakage. This leakage increased dramatically until a substantial portion of the coolant had been lost. In contrast, the Honda coolant had almost no leakage through the duration of the test.
    Chart here, entitled "Coolant Leakage from Water Pump Seal", showing Leaked Coolant Volume in ml as follows for each test duration in Hours:
    24 hrs: Honda Coolant 0, Typical Silicated Coolant 21
    48 hrs: Honda Coolant 1, Typical Silicated Coolant 36
    72 hrs: Honda Coolant 2, Typical Silicated Coolant 47
    96 hrs: Honda Coolant 2, Typical Silicated Coolant 55
    120 hrs: Honda Coolant 2.5, Typical Silicated Coolant 56
    144 hrs: Honda Coolant 3.5, Typical Silicated Coolant 57
    168 hrs: Honda Coolant 4, Typical Silicated Coolant 58.8
    192 hrs: Honda Coolant 6, Typical Silicated Coolant 63
    200 hrs: Honda Coolant 6, Typical Silicated Coolant 64
    - - Silicates tend to gel and settle in the coolest parts of the cooling system, causing radiator plugging and overheating.
    - - Borates cause pitting corrosion on the cylinder head.
    - - Silicate inhibitors are difficult to stabilize and, therefore, limit coolant shelf life.
    Most commercially available coolants were originally designed for cast iron engines. Silicate, an inexpensive additive, was added to coolants to prevent aluminum corrosion, but the long-term durability of the combination was not tested.
    In contrast, Honda coolant was designed specifically for aluminum engines. It contains an organic corrosion inhibitor instead of silicate. This superior formula gives these advantages:
    - - No silicate abrasion of water pump seals. For example, these graphs show the surface roughness of two aluminum water pump seal rings. Seal A, exposed to silicated coolant, shows considerable damage. Seal B, exposed to Honda coolant, displays only minute wear.
    [graphs here, showing roughness across the surface, with A a very wiggly line, and B a very smooth line]
    - - No plugging or overheating caused by silicate gelling.
    - - Excellent corrosion protection for aluminum components.
    - - Long-term corrosion protection for other cooling system materials (steel, cast iron, copper, solder, gaskets, seals, and O-rings).
    You can find less expensive coolants on the market, but now you can see why genuine Honda coolant is the only coolant approved for Honda and Acura vehicles (it MUST be used for warranty repairs). Honda's non-silicate formula delivers added protection not offered by 95 percent of other brands. Since our customers expect lower maintenance, you're doing them an injustice if you use any other coolant.
    Thanks sa Info sir. I'll stick sa OEM para sigurado.
Top1, Abro or Prestone Coolant
