Results 1 to 10 of 20
November 23rd, 2007 11:05 AM #1
may problema ata compressor ko.
i can hear it turning on/off even when inside the car. normal pa rin naman ang lamig ng kotse, pati yung frequency when it turns on/off. kaya lang rinig talaga. ano kaya problem? bearing? pabigay na ba compressor ko or kaya pa remedyuhan?
thanks.
November 23rd, 2007 11:26 AM #2
November 23rd, 2007 11:57 AM #4
ako naman nawala na ung pag click na sound unlike dati pag lumamig na.... magkano ba thermo switch?possible ba thermo switch? lumalamig pa rin e pero continous ang takbo ng compressor. my ride is a honda ESI
November 23rd, 2007 12:03 PM #5
baka may lumuwag na wiring connection somewhere? have it checked bro.
November 23rd, 2007 02:10 PM #6
- Jul 2004
- 22
November 23rd, 2007 02:48 PM #7yung sa akin mazda, ang problema ayaw mag automatic, so continous ang takbo ng compressor ang ginagawa pag malamig na sa loob ng car off ko muna.
ano kaya problema nito.tks
November 23rd, 2007 03:02 PM #8
Baka Sira na ang clutch ng compressor mo, or maybe the thermo switch din. Kasi di ba dapat when it reaches a certain temperature it will turn off?
- Nov 2007
- 3
November 23rd, 2007 07:13 PM #10check ur aux fan bka need for replacement na,pg mahina kc fan mag hihigh pressure ac mo,in will cause the on/off's of the compressor.
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
