Results 1 to 10 of 11
- Feb 2008
- 5
March 6th, 2008 05:53 PM #1mga bro, greetings!
got a prob with my temp gauge. last time sumasabay cya sa rpm then bumalik sa normal. this time wla cya prob as long as ur running below 100kph but if you keep ur speed sustained above 100kph for a period of time and of course sa nlex ko lang nagagawa to, eh tumataas na cya pero weird kc pag ineutral ko cya while running e bumababa din cya. wori ko lang kc na mareach nya max temp reading while running dba coz ishutdown ng comptr box ang engine for safety. i need your help mga bro if you have any idea to solve this problem. thanks!
March 7th, 2008 05:44 PM #2
I'm thinking it might be multiple problems. But it sounds like your water pump is slipping... Try driving at higher revs below 100 km/h and see if that makes the temperature rise. If so, then it's your water pump, for sure. It's not pushing enough coolant to cool the engine.
- Feb 2008
- 5
March 7th, 2008 05:55 PM #3thanks alot! il try to check the water pump if not change it with new one. hope this will solve the problem.
- Feb 2008
- 5
March 8th, 2008 01:54 PM #6
hey bro, lets all hope na may Thermostat ang makina mo
. kung meron, have that thing checked first. kung wala.. well paki lagyan nalang.
aite, peace.
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 16th, 2008 12:13 PM #7baka barado na radiator mo... kaya at high rpm/speed the engine is not supplied with enough water/coolant.
March 16th, 2008 10:06 PM #8
ganyan din ang nangyari sa civic ko. eventually nagoverheat din nung pinabayaan. it turned out yung sensor ang may problema. Hindi nya na-sesense na mainit na yung engine kaya hindi nya ma-on yung radiator fan. It's either sensor problem or yung fan mismo ang sira. delikado yan bro, ingat
- Nov 2003
- 3,848
March 24th, 2008 09:06 AM #9should be relatively easy to check which is really causing the problem naman.
- Feb 2008
- 8
March 30th, 2008 05:13 PM #10nangyari din sa akin to, pag apak ko ng gas bigla na lang pumapalo din yung temperature gauge, kakalikot namin nung electrician ang nakita nagloose lang pala yung body ground ng oto. nung nahigpitan ok naman na.
me relationship nga ba kaya yung dalawa?
Are they on track to surpass last year's sales?
Car Sales Data (2025)
