Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Aug 2005
    idle up mechanism nyan. sure ako .hehehe
    Jan 2004
    you can try to have the throttle body cleaned muna. kasi ganyan din yung civic ko dati. kaya pala ganun kasi, madumi yung throttle body, di makapag idle up kasi puro dumi na, nagstuck yung mechanism.
    Jul 2006
    Quote Originally Posted by lightninmcqueen View Post
    toyota xe unit ko, carburated. d kya yung equator ko yung problm. tsaka what meant pla dun s bumama yung rpm is yung tachometer reading ko. d b dpat pumalo pataas yung tach ko kya lng yung akin bmbgsak kpg ngaircon ako. can i mechanic solve this or i should bring it to a aircon specialist?
    "Bumagsak" is very subjective. When you just mean na yung RPM "dipped" as in kaunting baba lang, normal yan. The compressor uses 1 or 2 HP from your engine kaya yung rpm bababa.
    May 2005
    sa akin kapag i-oon ko lang ako a/c dun lang nagddown rpm ko. kapag wala a/c ok naman.
    nararamandan ko kasi nanginginig ang manubela.
    pero kapag wala a/c ok naman ang idling.
    parang a/c related problem....
help! rpm goes down when aircon is turned on
