Results 1 to 10 of 35
    May 2009
    eh di kung walang visible external leak eh internal leak na yan...panalangin mo na lang na head gasket lang..hindi cylinder head, or engine block.
    check mo ng maigi lahat ng hoses, water pump seal tsaka yung mga freeze plugs.
    check you engine oil too for water contamination.
    Quote Originally Posted by miked View Post
    walang tubig ang langis and im sure hindi head gasket,kung head gasket o cylinder head ang may tama di sana hindi ko na nagagamit at nag ooverheat na ko agad,
    nagagamit ko oto everyday from paranaque going up to valenzuela no overheat,
    i think its a pinhole leak somewhere na hindi ko mahanap,will keep searching for that elusive ****ing leak
    Jun 2012
    saan bang shop maganda magpacheck ng leak?? sakin naman sa reservoir lagi nagbabawas... na-top overhaul na din kasi makina kaya sabi normal daw magbawas tubig.. totoo ba yun??
    Jul 2010
    Ano ba gamit mo sa radiator mo? Coolant or ordinary tubig lang. Every gamit ba ng kotse ay bawas kaagad ang reservoir?
    Kung maganda pagka Top Overhaul sa engine ay dapat hindi mag leak ang coolant sa loob ng engine.
    Jun 2012
    Quote Originally Posted by Chinoi View Post
    distilled water lang po, walang halong coolant..
    every week ako nagrerefill sa reservoir eh.. ok lang ba yun??
    kasi kung normal lang maglalagay nako coolant and tubig 50/50
    Aug 2005
    Quote Originally Posted by OniLord View Post
    There are very finite causes of leaks unless your radiator itself is damaged.
    Check the following:
    1. Inlet hose and attachments from the engine to the radiator.
    2. Outlet hose and attachments from the radiator to the engine.
    3. Radiator cap.
    4. Thermocouple O-ring.
    5. Overflow pipe.
    6. Water pump.
    If no leaks are visible, check your radiator for leaks, tanks, headers, core.
    If no leaks are found there's a good chance its leaking into your engine. So check your oil.
    Once you find and seal the leaks, flush and refill your system with coolant mixture and clean water.
    check mo ang water pump, meron itong weep hole baka doon lumalabas, kailangan lang mainit na ang makina bago mo inspect ito para makita kung meron leak.
help with radiator problem
