Results 11 to 14 of 14
- Nov 2012
- 16
March 31st, 2013 07:36 PM #11mga sir, pinalagyan lang namin ng freon tapos pinalitan ung isang auring..aun, malamig na uli..kaya lang pag tinotodo ung aircon eh parang hindi maxado malamig..kaya steady na lng namin sa half. sbi nung naglagay ng freon, msisira na daw ung compressor..di ko sure. tapos po, ngayon naman, umaabot na sa red ung temp gauge simula nung pinaandar na uli namin ung aircon. at bumaba ata ang menor.haaay...hirap pala mag maintain ng car pag wala ka alam..sana matulungan nyo po ako..tnx!
March 31st, 2013 07:55 PM #12
there might have been a leak in the auring (o-ring) that cause the malfunction. with the a/c at maximum cool and the coolant temperature gauge reads overheat, that means the cooling system has a problem too. if the radiator temperature is high, the a/c will not work efficiently. have the cooling system checked too, check the radiator fan and the condenser fan for airflow
April 1st, 2013 01:35 PM #13
compressor can cost you around 12-16k, lahat na. kasama na linis and freon.
kung fuse o relay, mga 500 pesos lang.
kung freon lang, mga 800 pesos.
kung magnetic clutch, mga 2,500 pesos.
kung may leak, depende sa component na papalitan like evaporator, condenser...
kaya kailangan madala sa a/c shop talaga to properly diagnose it.
try bringing it at ceejays sa las pinas. check mo yung thread nila dito. medyo mahaba na.
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
