Results 11 to 19 of 19
December 27th, 2008 01:24 PM #11
madaming conditions eh.
pag nilalabas mo ba, coming from overnight parking? if this is the case, it is not water coming out from the AC system. this comes from the radiator or from the water pump.
ang water kasi coming from the AC is tutulo lang yan, after you've used the AC, pero kung galing overnight parking, hindi sya dapat ganun.
my additional questions: are you using a coolant? or plain water lang sa radiator mo?
on resetting the trip meter, di ba i-pre-press lang yan ng matagal? mag rereset na sya magisa?
- Oct 2006
- 50
January 2nd, 2009 04:53 PM #12Hi mga bro, may prob din yung '97 honda civic ko, may tumutulong tubig dun sa baba ng engine, at the driver's side.Could this be the water pump,san ba located ito?Nagbabawas sa ng tubig sa radiator, kanina ko pa inoobserve pero di ko po pinaandar engine....
- Oct 2006
- 50
January 4th, 2009 10:45 PM #14
- Nov 2008
- 25
January 6th, 2009 04:53 AM #15hi ulet mga bossing! yung dati patak patak lang na tulo lang under my car eh malala na ngayon. pagkaalis ko sa parking parang isang tabo ng tubig yung nabubuhos. so kala ko naman wala lang pero ayun, nag overheat nung nasa gitna ako ng byahe. so ang sabi may tagas na ang radiator. is there no other way other than replacing the radiator itself? kasi la pang budget sa ngaun. pero d ko rin naman afford na maglagay ng tubig everytime na aalis ako at pahinto hinto para magrefill ng water for long drives. help naman po dyan, mga sir.
January 6th, 2009 10:19 AM #16
- Oct 2006
- 50
January 6th, 2009 12:33 PM #17Ako din,kapag nagtuloy tuloy ang tulo sa rad malamang magpalit,magkano ba yung evercool for civic mga bro?single row lang yung stock
January 7th, 2009 11:46 AM #19
locate mo muna yung leak. if its sa upper or lower part ng radiator. if its a minor crack, try using Gladiator Radiator repair. i've used it and it temporarily sealed my leaking radiator for a few months.
VinFast VF 3
