Results 1 to 10 of 20
November 22nd, 2012 08:56 AM #1
guys okay lang ba yung universal na compressor sanden 508? mas mura kasi..
advise kasi nung tumingin sa ac ng pickup ko palitan na daw... nawawala kasi yung lamig every 10min ata tapos bumabalik rin pero hassle lalo na pag tirik yung araw ang init :| may sira ata sa bearing yung compressor kasi nung ni-rev niya iba yung tunog ng compressor.. tska nag babawas ng langis yung compressor. nung chneck rin yung pressure hindi gumalaw yung needles / walang reading
November 22nd, 2012 09:13 AM #2
Ano pong sasakyan sir? Pm niyo si akosijhepoi baka may surplus sila
November 22nd, 2012 09:13 AM #3
what car? kung toyota with lock-up sensor hindi pwedeng palitan ng sanden
November 22nd, 2012 09:21 AM #4
isuzu tfr 1994, meron kasi sa sul!t 4k lang brandnew daw.. sanden 508.
yung surplus kasi nasa 3.5k natanong ko sa isang shop...
November 22nd, 2012 09:24 AM #5
Mas mura kina jeff pero hindi sila nag iinstall. Yung shop malapit sa kanila ata ang magkakabit.
December 7th, 2012 10:18 PM #7
update..
bought the car to 2 different aircon repair shop.. pareho nila sinabi na O-ring lang daw sira nung compressor ko kaya nawawala yung lamig paminsan tapos babalik ulit. ang charge nila is 1.8k kasama na refill ng freon. mas okay ba ipaayos ko nalang yung o-ring or palit ng surplus compressor?
December 7th, 2012 10:31 PM #8
December 7th, 2012 10:32 PM #9
As per my experience, kung compressor overhaul lang (palit seals) hindi rin magtatagal, I had 2 compressors in 2 seperate cars fail within 3 months after the repair. Surplus compressors are out of the equation, baka mas malala pa ang condition ng surplus na binili mo kesa yung sayo. I bought brand new para iwas narin sakit ng ulo.
1Rotary along Evangelista in Makati sells quality Sanden 507/508 compressors that are Made in Singapore. I bought mine last year for 5.5K each.
Check their branches nearest to you here: 1Rotary
December 8th, 2012 02:14 AM #10
Depends din where the failed o ring is. In one unit, it was just the o ring as the hose exits the compressor. Quick fix lang
