Results 1 to 5 of 5
    Jan 2003
    when do u usually replace this belts?
    is every 20k kms a safe period? o dapat every 5k?
    thnx
    every 5000 km ay inspection lang yan, just check lang kung may cracks, and you can even spray it with belt dressing. pag may cracks na saka lang palitan.
    normal replacement interval would be around 30,000 km or more. nasa manual mo yan pards check mo lang.
    20000 km for fan belt replacement is too short an interval.
    Dec 2002
    I'm at 65k km on trooper with original belts(these are multi rib type), still ok.
    I think belts age over time rather than km run, so replace in about 4-5 years time.
    I normally change them at 40k, with checkup inbetween 5k.
    Kahit na buo pa or walang visible cracks palit na sa 40k. Mahirap maputulan at laking aberya sa byahe lalo na kung bibihira ang sukat.
    Dec 2003
    yep minsan mas ok preventive maintenance, safer pa especially with cars w/ 1 belt that drives the waterpump, alternator and powersteering all at the same time.
altertnator/aircon/fan belts when to replace??
