Results 11 to 20 of 21
April 6th, 2013 09:14 PM #11
actually kapag hinugot mo ang wire ng thermoswitch sa 4afe, automatic na mag on ang rad fan at hindi ito titigal hanggang nasa acc position ang susi. kung umaanda ang fan ibig sabihin hindi sira ang relay. may ginalaw ba sa wiring para ma rekta yung rad fan? dapat kasi automatic na on rad fan mo kapag di naka plug ang wire sa thermoswitch
- Apr 2011
- 66
April 8th, 2013 10:47 PM #12I've been using a Circuit brand thermoswitch on my EE90 for 2 years now, used in heavy traffic everyday - still works.
*gabygab - agree with j_dipad, have your fan wiring checked.
- Mar 2013
- 15
April 9th, 2013 01:59 PM #13Hinugot ko lang mga sir sa switch andar na radiator fan.
Just this morning as I am checking my aircon fan dahil not working, kinabit ko na sa switch ang radiator fan and turnned on the aircon. To my surprise nag auto na rad fan at 80 sa gauge ko. But pag off ang AC hindi nag o ON ang Rad fan so binunoyt ko ulit para di mag overheat. pag lamig ng konti aroun 80 ON ko AC and kabit ko rad switch automatic na ulit. GAnun ba talaga?
wala kasi ako wiring diagram kaya di ko macheck.
Another problem now is AC fan sometimes do not turn ON as I turn ON the AC. Checked it already by directly connecting at the BATT and it turn on.
But sometime it cycle on and off. Sira naba AC fan ko?
- Mar 2013
- 15
April 15th, 2013 11:28 AM #14Problem solved.
Replaced the Condenser fan motor.
As observed radiator fan turns ON at around (95 deg C) even with Aircon switched OFF.
- Sep 2013
- 153
Tsikot Member Rank 4
- 2,719
November 9th, 2013 10:33 PM #16^ sabay sa compressor ang aircon fan, auto on/off sila habang gamit ang aircon
- Jul 2012
- 329
February 1st, 2016 09:26 PM #17Buhyahin ko lang tong thread.. Dpat ba ikot rad fan kaht patay aircon? Honda jazz 05.
- Jul 2012
- 329
February 5th, 2016 05:38 AM #18mga sir mag papakabit po ako thermostat at thermoswitch for my jazz 05.. balak ko sana palitan radiator hose.. ok lang ba stock ulit bilhin ko or upgrade to samco? how much po ba ung ganun?
February 5th, 2016 04:12 PM #19
What will be the added benefit of installing the samco?
I'd go with the stock hose
Sent via Tapatalk
- Apr 2016
- 7
April 10th, 2016 12:46 PM #20Gumamit nako ng brand na ganyan, hindi masyado accurate kahit di pa maiinit engine uma andar na ung fan, kaya ginawa ko nag series ako ng potentiometer pag nasa target temperature na ung makina adjust nyo ung potentiometer hanggang umandar ung fan.. Patulong nalang po kayo sa nag eelectrical or electronics mura lang ung parts na yan
medyo disappointing itong Sealion 5 No ADAS No 360 camera
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
