Results 1 to 4 of 4
    Nov 2007
    Mga paps help nmn. Tumataas temp pg on ang aircon sa tanghali after 1 hr of driving. honda esi. nu kya problem?ok nmn ung 2 fan (radiator and condenser.) pg pinatay k ung aircon back to normal ung temp ko. help nmn. thanks
    sana nag SEARCH ka sa mga previous forum topic...
    pero kung tinatamad ka... eto ang opinion ko (in order of priorities):
    1) Auxiliary fan of condenser is not running or baka baligtad ang ikot.
    2) Auxiliary fan of condenser is no longer "worthy"... yung bilis ng ikot ay mabagal na kasi the motor needs servicing or replacement.
    3) If 1 & 2 is not an issue, radiator is probably clogged. Considering that your car is old, hindi kataka-taka ito.
    4) Water pump is no longer functioning properly (needs replacement)... kaya pag may load hirap na itong mag-pump ng tubig.
    Nov 2007
    Thanks s reply paps. OK nmn ung condenser fan ko. sbrang lkas p ng buga ng hangin. Ung radiator nmn kaka overhaull lng. Bka water pump n ah. pnu boss mllman if defective n un? if ok sya anu p kya possible reasons why gnun. thanks po ulit,.
    Sep 2006
    If all mentioned was working pretty well, try to change the actuator (im not sure if thats the correct spelling) but I have experienced this already in my car and sa laki ng nagastos ko hindi naayos. Tpos in the end, yung actuator pala ung nagcocause nung fluctuation. This is just a suggestion. Its around P150-350.00 lang. look at your nearest aircon shops. DIY to so dont try to pay some labor on this.
