Results 1 to 7 of 7
- Oct 2014
- 162
September 28th, 2016 06:35 PM #1Ajter 2 months from radiator overhaul, just found out the coolant reserved tank is empty while the radiator is still fukk. Is it normal? Do i kust only need tp replace the coolant reserved tank with the same mix (50-50)? Thanks.
September 28th, 2016 06:48 PM #2
Maybe you forgot to fill it after the overhaul?
At this point, all I can suggest is fill it with coolant (same ratio as what you put in the radiator) and observe.
September 28th, 2016 06:49 PM #3
Not normal.
Two possibilities:
1. You have a leak somewhere.
2. You need to replace your radiator cap.
- Oct 2014
- 162
September 28th, 2016 06:57 PM #4
- Oct 2009
- 2,271
- Oct 2014
- 162
September 28th, 2016 08:15 PM #6
- Jul 2013
- 2,450
September 29th, 2016 10:24 AM #7Just fill the coolant reserve tank then observe on a daily basis kung nagbabawas pa at kung gaano kadami nababawas.
Yung radiator cap nabibili yan sa auto supply. Hanapin mo lang yung tamang size at pressure rating.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
