Results 11 to 14 of 14
October 11th, 2014 10:06 PM #11
hoses previously used with R12 systems maybe used with R134a. new hoses made for R12 will leak if used on R134a.
to determine the high side pressure without the discharge service port, you can use an infrared thermometer on the upper tube of the condenser and compare the temperature to the pressure using the R134a pressure/temperature chart. the other way is to compare the temperature of the condenser top with the pressure/temperature dial of the manifold gauge. this will give you about 90% accuracy of the estimated pressure
- Aug 2012
- 2,767
October 11th, 2014 10:22 PM #12R12 parts replacement
Remove the components to be replaced as part of the retrofit to R134a, as recommended by the A/C system or vehicle manufacturers guidelines.
THE MINIMUM:
- Filter drier or accumulator;
- High side system "O" rings through to the evaporator inlet;
- Add 30-50ml PAO oil to a/c system.
- Fit high/low side R134a charging port adapters (use a thread lock to secure to R12 charging ports)
- Retrofit warning labels.
October 11th, 2014 10:55 PM #13
- Oct 2009
- 2,271
October 12th, 2014 06:52 PM #14kung palit freon ka lang at kailangan eh 134a papalitan lang ng expansion valve yan saka filter dryer.vacum flashing saka kargahan na ng 134a na freon kung good pa ung compre mo..pero sigurado akong copper pa ung evaporator mo kaya mas maganda kung mapa litan din ng aluminum evaporator.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
