Results 1 to 14 of 14
    May 2009
    This is more like an LTO registration issue.
    i have to admit R12 yung system ko. but by the time na nagrehistro ako ng sasakyan e mahina yung A/C. nirason ko na lang na di ginagamit ang A/C. sa pananalita ng LTO inspector, mukhang gusto nya ako huthutan ng pera dahil non-A/C nakasaad sa rehistro ko. nirason ko naman na reyna ng garahe sasakyan ko most of the time. kesyo kelangan ko pa daw ng certificate from A/C shops na magpapatunay na R134a nga dahil bawal na daw R12, etc.
    pero gusto ko rin syempre na magamit pa rin yung A/C ko. so ang tanong lalu na sa mga nakaexperience neto ay may kelangan bang palitan na major part (comp, cond, evap, drier/filter, hoses)sa A/C when converting from R12 to R134a?
    i have read somewhere before na yung o-rings for r12 ay hindi compatible sa R134a, etc, etc, blah blah.
    Jun 2014
    Its a different gas that may not be compatible
    Apr 2010
    Change compressor na lang since sabi mo mahina na rin ang system. Pwede mo pa ring ibenta ang luma sa mga AC shops.
    Full flushing lahat ng tubes, condenser, evaporator. New drier and expansion valve
    Yung sa akin dati pinaconvert ko rin sa 134a pero intermittent ang lamig. Pinatignan ko sa Petron dito sa amin kasi parang may computerized gas analyzer sila for AC, may halo pang at least 15% na R12 at ibang flammable gases yung sa akin (di siguro na flush ng mabuti)
    May 2009
    Quote Originally Posted by ParticleX View Post
    ganon? palit compressor agad dahil sa mahina? i had it pressure tested last time e ang sabi mahusay pa ang compression sabi nung AC tech. i actually have a thread with regards to this problem.
    Feb 2009
    to check compressor integrity, run the engine with the compressor clutch engaged at at around 2500 rpm, the suction pressure should drop below 28 psig. to check the high side, unplug or disable the condenser fan. the pressure should rise to around 200 psig at idle, around 230 or higher at around 2500 rpm. to retrofit, remove the compressor and drain the oil and replace with either polyol ester (POE) or polyalkylene glycol (PAG) oil. change the receiver drier to X7, change all the o-rings to the green ones (HNBR)and change the thermostatic expansion valve designed for R134a. add more airflow to the condenser by either to a bigger CFM fan or add either a pull or push fan whichever is applicable.
    Apr 2010
    Di naman necessary, para less hassle lang in the future. It could leak kasi as I understand R134a molecules are smaller than R12.
    Change seals, o-rings, old oil from your compressor to R134-compatible.
    May 2009
    now i know. marereckon ko na ang gagastusin. salamat sa inyong lahat.
    May 2009
    the problem is that it does not have an service valve on the high side. only on the low side. cycling clutch system.
    the AC tech actually did what you just mentioned, but without a tachometer. he said the compressor is ok that time based on the suction reading he made.
    May 2009
    how about the hoses?
    Jun 2011
    Sir... The best shop mag convert and most honest.. Sa EDS Sir kung malapit ka Mindanao ave. Quezon city dun nyo nalang po dalhin..
    Feb 2009
    Quote Originally Posted by miked View Post
    hoses previously used with R12 systems maybe used with R134a. new hoses made for R12 will leak if used on R134a.
    to determine the high side pressure without the discharge service port, you can use an infrared thermometer on the upper tube of the condenser and compare the temperature to the pressure using the R134a pressure/temperature chart. the other way is to compare the temperature of the condenser top with the pressure/temperature dial of the manifold gauge. this will give you about 90% accuracy of the estimated pressure
    Aug 2012
    R12 parts replacement
    Remove the components to be replaced as part of the retrofit to R134a, as recommended by the A/C system or vehicle manufacturers guidelines.
    THE MINIMUM:
    - Filter drier or accumulator;
    - High side system "O" rings through to the evaporator inlet;
    - Add 30-50ml PAO oil to a/c system.
    - Fit high/low side R134a charging port adapters (use a thread lock to secure to R12 charging ports)
    - Retrofit warning labels.
    May 2009
    now i have another reason to buy a new toy! hahaha....
    Oct 2009
    kung palit freon ka lang at kailangan eh 134a papalitan lang ng expansion valve yan saka filter dryer.vacum flashing saka kargahan na ng 134a na freon kung good pa ung compre mo..pero sigurado akong copper pa ung evaporator mo kaya mas maganda kung mapa litan din ng aluminum evaporator.
Converting from R12 to R134a
