Results 1 to 7 of 7
Tsikot Member Rank 3
- Oct 2003
- 734
November 21st, 2007 08:19 AM #1hello!
matanong lng eh ayaw umandar nun blower ng oto pero may aircon i mean yun compressor gumagana ksi pag on ko nun a/c tumataas yun rpm pero walang blower? naencouter nyo na siguro eto. sa fuse ba kaya ito o relay? ang relay ba neto ay yun a/c clim fan or something like that tinignan ko ksi sa harap ng oto? kung papatignan kok naman sa electrical ba ito o sa aircon repair shop?
thnx
November 21st, 2007 09:21 AM #2
nurse on wheels
- Dec 2006
- 392
November 21st, 2007 10:58 AM #4happened to me before.it wasn't the fuse but the blower. but you should check the fuse first.
November 21st, 2007 11:05 AM #5
i agree..check fuse or try mo rin tap ng medyo malakas ung sa ilalim ng glove compartment mo
November 21st, 2007 08:54 PM #6
POSSIBLE CAUSE:
Busted fuse
Busted blower
faulty wiring
if you have a multitester try mo check
1.fuse for continuity if ok goto 2 if not replace
2.removed electrical connector/plug sa blower, ign key to acc, on a/c, using multi tester check voltage on the connector/plug sa blower , if theres no voltage reading sa connector/plug meron putol na wire, if theres a reading try to clean the contact ang reinstall the connector/plug. and check if the blower will operate. if not busted blower.
same experience ko sa iyo ang naging problema yung connector nagloose contact kaya nasunog na yung wire sa connector nag iinit kasi, pinalitan ko lang g connector ok na.
November 24th, 2007 11:59 AM #7
puede blower motor mo it is beside the evaporator pagawa mo sa banaue sa INDIE it is near ONE spa very good shop
https://www.autoindustriya.com/auto-industry-news/mitsubishi-ph-prepping-to-launch-rebadged-nv350-ur...
Mitsubishi Philippines
