Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Jan 2011
    Mga sir at expert jan may problema kotse ko d umiikot yung rad fn at a/c fan dinagdagan ng freon ng kaibgan ko tapos ang ginawa niya habang umaandar makina binuhusan ng tubig ung radfd fan at a/c fan tapos ayum ok naman umiikot sya like normal .. Tapos kinabukasan nung pag on ko ng aircon napansin ko d lumalamig yung a/c kahit naka high temp siya nung buksan ko yung hood nakita kond umiikot yung a/c fan at rad fan kahit naka on na yung aircon.. Ano kaya problema nito check ko na yung fuse ok naman lahat samantala bago dagdagan ng freon eh ok pa yung mga fan .. Sabi ng kaibgan ko baka daw may leak na kaya d umiikot paano ba maganda gawin dito paano ba basic troubleshoot ..?? O maganda pa check ko muna sa aircon shop.?? Thanks sa makakasagot
    just bring it to the aircon fixit shop, sir.
    they'll trouble-shoot it faster than i can describe it here.
    Oct 2014
    Have it check in a shop sir. But my guess is napasukan siguro ng tubig yung fan motor kya di umiikot. Try to spin the fan blades with a screwdriver check mo kung aandar.
    Jan 2011
    Thank mga sir sa quick response niyo ... Dko pa nadadala sa a//c shop balak ko palang ipacheck...
    About naman dun sa paikutin yung fan is gumana siya sir kaya lang after a few seconds d na ulet umikot at until now kahit paikutin mo ayaw na gumana.... Ano kaya posible cause d kaya dahil sa pagkakabuhos ng tubig habang umiikot yung fan .??
    most probably, sira na yung motor ng radiator fan.
    matigas na yan.... parang household electric fan na bumara ang alikabok sa motor and ayaw ng umikot.
    Feb 2005
    Just replace your fan motor. Yun ang sira nyan. Depende sa auto, it could range from 3k to 6k, band new.
    Feb 2009
    Quote Originally Posted by johnlward18 View Post
    to eliminate the possibility of the motor being the cause, try connecting the motor using a fused jumper to the battery and ground. if the motor runs, the trouble could be of the wiring, controls, relays or maybe even the pressure switches since you mentioned you just had the air conditioner repaired.
    Jan 2014
    dats korek better pa tsek mona yan bro sa aicon technician, alam na niya ang gagawin diyan para ma tsek na niya lahat, hindi kaba nataas ang temp gauge mo pag nag oopen ka ng erkon lalo kamu at di nagana fan niyan..
    tama or try mo obserbahan kung aandar ang radiator fan pg mga kalahati na ang temp mo... now pg di umaandar ang aircon fan try mo pacheck kung may freon pa pg ala di talaga aandar ang mga fan pg nkaaircon,.
    what is your car po?
    Jan 2011
    Mga sir thanks ulet sa quick response niyo..
    Maluwag naman po siya mga sir pag iniikot ko eh kaya nga lang ayaw talaga umiikot unlike before na sobrang lakas tlaga ng buga ng hangin pag naka on na aircon..
    Saka nagtry din ako mag aircon pero wala talga lamig kahit naka kalahati na yung temp ko d naman siya tumataas sa kalahati ..
    d kaya sir dahill wala nga freon kaya d umiikot isa kayamg possible cause yun.??
    Yun car ko po is honda city 97model
    imho, not necessarily na malambot sya ay iikot sya. baka sira yung carbon bushing sa loob.
    hindi related yung freon sa hindi pag ikot.... separate problem yun.
    pa check up mo na lang yung fan and yung freon level.
    Oct 2009
    pag dina umiikot ung AC fan mo siguradong hindi nadin lalamig ung AC mo kasi mag high temp na ung condenser.
    try mong i manual paikutin ung ac fan mo habang naka on ang aircon,kung baga tulungan mong paikutin ingat lang bro at baka biglang imikot iwas mo kamay mo..
    sa akin kasi madalas din masira yan AC fan ng condenser ko kaya lagi kong tinitingnan.kapag medyo mabagal na hanap na akong pamalit sa mga surplus station dito sa evangelista ako nalang mag papalit ,kapag mahina na kasi ikot nyan hindi na lalamig ng maganda AC mo.
    pacheck mo muna sir pag ala na talga yan freon di yan aandar pag naka aircon umaandar nlng yan pg mejo ngooverheat ung mataas na talaga ang temp mnsan sa kalahati ng gauge aandar un minsan tpos titigil din pag bumaba na sa kalahati try mo obserbahan kahit anjan ka lang sa garahe.. mas maganda pacheck mo muna kung may freon nga kung ala pahanap mo nalang ung singaw aandar lang yan pag may freon na,. di ka naman ng oover heat eh kasi umaandar un pg mejo nasa kalahati na un ang sina sabi ko na obserbaahan u mejo nasa kalahati na or up kung aandar ang fan.
    Oct 2014
    Madali yan i check sa mga auto shop sir kung yung motor ng fan ang sira. If that's the case dont drive it in the city kasi bka mag overheat ka sa traffic pag di umiikot yung fan. I have experienced the same problem before and I have to replace the motor of the fan. Cost me around 1k for the new motor.
    Sep 2012
    Regarding your freon charge the best one to check that is a reputable a/c shop.
    Regarding sa fan mo, here is a trick that I will share with you.
    Baklasin mo yung aircon fan assembly up to the motor. Dont worry about the wires kung baliktad mo sya maibalik kasi hindi naman mag short yan... Babaliktad lang ikot ng fan and you will just have to interchange kung mali.
    Once nabaklas mo na, look for the brand and part number of the motor. You are in luck if its a Denso brand kasi pwede ka makabili ng generic fan ng Denso sa auto supply for 450 to 650 depende kung saan ka bumili brand new pa.
    Baklasin mo lang din motor ng bago then ilipat mo sa housing na luma mo. Usually, parehas motor nyan ibaiba lang housing due to the design of different cars. Kung trip mo rin yung elesi ng bago ilipat mo rin mas maganda kasi yung nas maraming blades
    Bago mo ibalik, i rekta mo sa battery para makita mo direction ng ikot ng fan. Then reassemble mo na sa body.
    Once na rule out mo na yan fan you can go ahead sa ac shop for other diagnosis kasi wala ka rin naman nabanggit na reading ng high and low side pressure reading mo
    Jan 2011
    Mga sir salamat sa response niyo.. Kung iikot ba ulet yung fan lalamig na kaya ulet yung a/c .?? Before kasi ngkaganito medyo malamig naman siya kapag malamig ang panahon pinadagdagan ko lang ng freon sa kaibgan ko tapos naging ganun na ... D kaya dahil sa pagkakalagay niya ng freon kasi ang sabi niya kaunti langg daw yung nailagay niya freon kasi naubos na yung nasa tanke niya... Iniisip ko naman baka nga dahil dun kaya d na umiikot yung mga fan ko .. Tapos nung binalik ko sa kanya sabi niya baka daw may leak kaya nagkaganun ..
    ibig mung sabihin, matagal nang may tulo yang aircon ng sasakyan mo, at palagay-lagay ka na lang ng freon para lumamig??!!
    hijo, pagawa mo na nang matino! alam mu ba kung magkano ang freon at anong ginagawa nito sa hangin natin kapag may tulo ang aircon!!
    "malamig naman siya kapag malamig ang panahon.."... ang ibig sabihin nito, ay palaging mababa ka sa freon, na halos hangin na lang ang laman ng aircon mo..
    errr.. ano ba ang sasakyan mo? kasi, may mga sasakyan na pareho ang aircon fans at radiator fans.. at kapag hindi umikot ang fan, ay overheat ang makina..
    Jan 2011
    Di po sir ... Wala po siya tulo or problema before ... As in ok po siya kumabaga may lamig din siya kaya lang d kasing lamig ng isa namen sasakyan ,., ang nangyari lang po kasi is dinagdagan lang ng kaibgan ko ng freon first time lng po iyon ... Tapos ito na po ang nngyari d na nga gumana yun mga fan ,,, tapos nung sinbi ko sa kanya sabi niya baka daw may singaw ...yun lng po ang sabi niya ... Pro papacheck ko na ren po sa a/c shop para mas mzganda... Update ko nalang po ito thread ko kung ano nangyari slamat po
    Feb 2009
    try running the fans direct to power source. then have the static pressure checked using the r 134a pressure/temperature chart:
    Pressure - Temperature Chart for HFC-134a
    if the pressure is not within the temperature range, have it serviced.
    adding refrigerant without adding the proportionate amount of PAG oil will cause compressor oil starvation.
    if the refrigerant had been leaking, the oil leaks with it since the oil is miscible with the refrigerant and hence will be leaking as well. have it serviced by a qualified and competent technician. DIY without the knowledge, proper equipment and training just ends up in system failure
radiator at a/c fan di umiikot
