Results 1 to 7 of 7
July 29th, 2009 04:19 PM #1
after mga 5 minutes pagka on ng aircon, nasusunog kaagad ang fuse.
yung battery warning light ko umiilaw ilaw din kung minsan. connected kaya to sa aircon?
makakatulong kaya kung maglagay ako ng grounding kit? considering na luma na din auto ko.
any inputs mga sir bago ko sana pa check sa mechanic? wala pa kasi time magpaayos.
tia.
'97 sentra efi
July 29th, 2009 04:26 PM #2
Have the compressor clutch checked. The windings could be shorted or started to short out.
July 29th, 2009 04:43 PM #3
Usually, pag nagso-short yung fuse, magnetic (clutch) coil nga. Calsonic pa ba ang compressor mo? Nung nagpaayos ako circa 2004, 1.4k ang price nun, pero yung talyer kasi ang bumili nun, kaya napamahal ako.
No choice, kasi 1st time ko yata magpagawa ng aircon, hehehe.
July 29th, 2009 05:21 PM #4
thanks sa inputs mga sir.
sanden yung compressor ko. yung para daw sa mga van sabi ng aircon technician. pinapalitan ata nung dating may ari.
ok pa naman siya since nabili ko mga 6 months ago. ngayon lang talaga nagloko.
- Aug 2009
- 31
August 27th, 2009 01:34 AM #5
August 28th, 2009 11:59 AM #6
pareho lang ng rating yung pinalit kong fuse sir...
pa check ko next week para magamit na ang aircon... mainit na din dito sa baguio.
September 2nd, 2009 11:33 AM #7
[SIZE=3]Other than cutting the supply of electricity to prevent further damage, fuses are meant to warn you that there is something wrong with the electrical system. Have it checked by a professional electrician (auto) ASAP! [/SIZE]
