Results 1 to 9 of 9
August 17th, 2013 04:28 PM #1
Hello fellow tsikoters...question..my ride is a manual 2nd gen honda crv...problem sa compressor noise...pag naka engage yung compressor ay walang ingay na whistling but pag na disengage yung xompressor may ingay nasiya..
Ano po kaya problema dun? Pls help
August 17th, 2013 08:12 PM #2
Your compressor clutch is not disengaging fully, hence the plate is slightly rubbing. Taga imus ka di ba? May suki ako na aircon shop dyan sa may Harap ng south super market. St Bars ang pangalan, you can have it checked there.
August 18th, 2013 11:18 AM #3
Hi sir..
Yun din ung duda ko...may masisira ba dun if dkopa papacheck? Kasi may lakad pa kasi akong importante..
- Apr 2010
- 268
August 18th, 2013 11:21 AM #4
August 18th, 2013 11:49 AM #5
Problema dito is pag walang aircon ang ingay..pag may aircon normal siya..
- Oct 2009
- 2,271
August 18th, 2013 02:26 PM #6like sa vti ko ,pag naka engage may humming ako naririnig..wwwoooohhhnnngggg...pag naka on naman maingay...parang kumakalampag..
palitin na kaya ung buong compresor or bearing lang kailangan palitan..
August 18th, 2013 03:06 PM #7
Compressor clutch Lang ang problem. It has to be adjusted, a thing those AC guys know how to do. There's a minimum gap in between the plates of the clutch. The AC shop should know that.
August 18th, 2013 04:31 PM #8
Pina check ko sa saint bar infront of south supermarket..sabi nila pulley bearing raw ung tumutunog..papacheckkopo bukas...
August 18th, 2013 07:05 PM #9
Nag engage and on is the same thing..iam assuming on and off..kung pareho may ingay..pa check niyo napo...or bettwr yet buy a new compressor..
I received this email from Fleetguard Understanding coolant and recommendations I think this...
