Results 1 to 11 of 11
    My ageing Corolla had its Heater core leaked, and was forced to just remove it thinking that it was a good idea since we really don't need heaters in our country. I was also aware of the cost if it need replacing, thus the removal. I temporarily blocked the supply hoses using the available plugs in the market. My dilemma is that I really don't know which one is better, Blocking or Bypassing. Some say plugging will cause restriction in coolant circulation (if the thermostat is closed), while Bypassing reduces pressure in the system. I don't know which one's best for my engine.
    I will appreciate thought regarding this. Thank you!
    Jul 2006
    Bypass.
    Jury rig a pipe with flexible extensions on both ends for it.
    I have old cars too, all are bypass.
    Bypass.
    Is bypass better than capping off the inlet and outlet? My old car was factory bypassed (got clogged and had very hard to detect pinholes) and my friend's car of similar make was capped (leaked too but kinda easier to check).
    Jul 2006
    I'd like to think so. My bypass tubes are all outside already (engine bay) where its easy to check should they leak. The system holds a bit more coolant too (as compared to a plugged one), so I think that's one benefit there.
    I think most Japanese FWD engine designs route the bypass under the intake manifolds between the block and the firewall.
    Ah yes, a bit more coolant. Thanks for your comments, Sir LSB!
    The shop did that to the jimny when they replaced the compressor. They bypassed the heater tubes.
    I remember, it was the same process (Bypass) done to my Delica before. I guess I have to do the same with the Rolla before letting her go
    Thanks dreamur!
    Oct 2009
    bypass mo nalang ..
    sa akin sa civic ko nag leak sa loob kaya ginawa ko binaypass ko nalang wala namang epekto sa cooling system.
    Oct 2013
    Quote Originally Posted by jvnj View Post
    blocking, just like what we have with the vios, 1 & 2 nz-fe have pipes from the water pump going to the heater core in the cabin... but since the vehicle in the philippines are not fitted with a cabin heater core, said pipes are blocked by a rubber plug...
    if you maintain a good coolant system it shouldn't be a problem...
    Quote Originally Posted by Stigg ma View Post
    Presently, I already tried both. Seems they have both the same good effect, or no effect at all in the cooling system. Thanks for all your comments!
Blocking or Bypass of Heater Core lines, which one's better?
