Results 1 to 20 of 21
    I noticed that different vehicles have different thermostat settings. Like the Isuzu 4jg2 theremostat is rated at 82deg while a Mitsu 4d56 is 79 deg.
    Now with this in mind does this make the overheat temp different for both and what temperature is considered as overheat for a diesel engine? 120deg Celsius? Thanks!
    Quote Originally Posted by edtf View Post
    It depends upon the design of each engine kasi. Yung nipis ng engine block, yung laki ng holes na dinadaanan ng coolant/water will be a factor. Mas malaki engine block at malalaki holes, mas matagal mag-overheat afaik. Hindi lang Isuzu ganyan, per car manufacturer meron din for sure na different overheat temp depende sa design nga ng engine.
    Feb 2009
    the temperature setting stamped on the thermostat is not the overheat temperature setting. it is merely an approximate temperature at which the thermostat begins to open. the engine operating temperature during optimum operation is between 190 to 240 degrees fahrenheit. bear in mind, that you can not base this on the boiling point of water from sea level up to about 1000 feet above sea level. the coolant solution is a mixture of anti-freeze/anti-boil coolant and water and is subject to as much as 12.8 to 16 psig that raises the boiling point about 3 degrees fahrenheit per psi of pressure increase
    yup understood I know that temp stamped of thermostat is opening temp of thermostat. So more or less that is optimum operation temp. What is now more or less overheat temp of diesel engines?
    Hmmm thanks bro ry_tower but what is the general range of overheat?? around 190-220 deg Celsius??
    Feb 2009
    by 190-220 celsius the engine might already have locked up. maybe you mean 190-220 fahrenheit sounds like most diesel engines operate at optimum. above the 220 degree fahrenheit mark, nitrogen in the air reacts with combustion creating oxides of nitrogen (air pollutant), the engine oil starts to degenerate, metals tend to expand more than the designed expansion rate (aluminum piston expands more than cast iron engine block) and the engine efficiency declines
    190 fahrenheit is just 87 celsius. Hindi pa nga boiling point ng water eh so i'm sure the engine won't seize in that heat level, even 220 fh is just 107 celsius so ok pa naman. Baka nga 190-220 fahrenheit ang optimum temp ng typical production diesel engine.
    May 2009
    recall from our basic physics that water boils at 100 deg C at atmospheric pressure of 14.7 psi (101,325 Pa). this is the case when we are not using a rad cap. if we are using a cap, we are increasing the pressure and as a result the boiling temp is also increased. add ethylene glycol (prestone, etc.), you further increase the boiling temp. and as the elevation increases (ex. going to high places like baguio, etc.), the boiling pt of water decreases. so boiling temp is a function of pressure.
    meself uses 82 deg C thermostat on a 4d56 turbo (no intercooler). just overheated this monday due to a loose alternator adjuster bolt. temp reach as high as 240 F on the mechanical gage while the stock electric gage is just beginning to rise from the normal range. no abnormal engine sound or vibration present and truck pulls normally when at 240F. engine started right away after the tensioning. to answer sir edtf's question beyond 240F (115C) could mean a blown engine as per my experience. i also experienced running the truck before at 212F (100C) for about 10-20 mins.
    me too have a question: why is it that some engines have their thermostat located at the lower hose (suction side) rather than on the upper hose (discharge side)? any explanation? thanks
    Feb 2015
    sir nag p plit nq ng cylinder gscket.. at overhul ng radiator.. pinatanggal q nren thermostat.. at pinalitan nren temperature unit bkit na taas pren temp q lalo na pag sa ahon ang takbo.. coolant rem gnagamit q? pti takip mg radiator pinalitan q nren. nka po my idea kyo
    Jan 2004
    Quote Originally Posted by tamchumacera View Post
    please refrain from using textspeak
    May 2009
    Una, palitan yung thermostat kung in doubt sa operation. wag na wag mong tatanggalin.
    Pangalawa, yung temperature sensor ay for monitoring. hindi masosolve neto ang overheating kapag pinalitan.
    Pangatlo, ang tendency ng water pump kapag mabilis ang rebolusyon ng makina ay syempre bibilis din. idagdag mo pa rito ang pagtanggal ng thermostat, wala nang oras para mabawasan ang init ng coolant sa radiator. kelangan bumagal ang ikot ng water pump kapag "high rpm" situations. papano? sa pamamagitan ng tamang tensyon sa v-belt AT tamang operation ng fan clutch. ang purpose din ng fan clutch ay para bawasan ang ikot ng water pump (para hindi magoverdischarge ang coolant flow). tapos magdidi-engage ang fan clutch everytime na maabot ang tamang operating temp ng makina.
    Pangapat, siguraduhing hindi na kasinglambot ng ispongha ang lower radiator hose (at di rin kasingtigas ng bato ang upper hose). kapag napakalambot na ito (lower hose) e nagco-"collapse" kapag mabilis ang ikot ng coolant (water pump). imaginin mo yung pagsipsip ng inumin gamit ang straw. kapag nagcollapse ang hose e magkakaroon ng vacuum sa cooling system. ito ay magreregister ng mas mataas na reading sa temperature gauge.
    Pangapat, mahirap basahin ang jejemon language.
    Mura lang naman ang thermostat. kadalasan nasa P500 yung TAMA brand na sa aking pagkakaalam e OEM quality.
    Feb 2015
    nung pag ka over hole kc ng radiator ko , tinanggal na nila thermostat ko , kc daw d advisable dto sa pinas kaya pwede daw tanggalin na,, yun temperature ko sa gauge lampas kalahati, nilagyan nila grounding kit pero ganon pren nman
    pa-baliik mo. they do not know what they are doing.
    Feb 2015
    cge slamat
    May 2009
    mga mekaniko mo siguro ang di advisable sa pinas.
    bili ka na lang ng bagong thermostat at ipalagay mo. pero huwag kalimutang ibleed ang cooling system once na malagyan ng thermostat. i.e., paandarin lang ng paandarin hanggat marating ang operating temperature ng makina (bubukas yung thermostat at mapupurga yung natrap na hangin sa mga water jacket).
    huwag magtextspeak brader. kahirap basahin talaga.
    Jul 2010
    Hindi maglalagay ang halos lahat ng car manufacturer ng thermostat kung walang magandang purpose iyan. Ayaw nila mapintasan mga ginawa mga kotse at dapat meron niyan.
    Kahit saan bansa ay sigurado ay halos pareho ang normal running temperature ng engine.
    Hindi maglalagay ang halos lahat ng car manufacturer ng thermostat kung walang magndang purpose iyan. Ayaw nila mapintasan mga ginawa mga kotse at dapat meron niyan.
    Mar 2013
    ^baka mabagal ikot ng fan sir
    Feb 2009
    Monkey see-monkey do. Monkey don't think. Hear and believe-how gullible. Technology is so advanced and people are still stuck to the wrong past procedures
thermostat and overheat
