Results 1 to 11 of 11
    When do you know it's time to replace the fan & motor assembly. I have a 2002 Urvan and the casa recommended replacing the fan & motor assembly kahit wala akong naririnig or nararamdaman na kakaiba. What do I have to look out for to be sure it is time to replace? Ang mahal kasi, P13,717.50 for a new fan & motor assembly + P983 sa labor.
    Quote Originally Posted by luloym View Post
    alas, i don't think it's in the manual or maintenance schedule. in my experience, i was having overheating problems in my sentra. i thought my fan was ok, until the mechanic showed me a new unit and just how strong the wind should be.. and if you are willing to gamble, you can probably save a lot (over 50%) if you have it done outside the casa. the fan is a low-tech part; any decent mechanic should be able to do it. just be sure you get a good replacement (japan sana and not taiwan).
    actually, before the overheating, i first brought the car to the casa for another problem. they fixed the problem, and recommended i replace both fans because they were about to fail. hindi ako naniwala dahil malakas pa naman ang hangin. nag-overheat. pinagawa ko sa labas. pinalitan ko yung mahinang fan. after a few weeks, the other fan also slowed down and i had to replace it.
    i guess it means, if their mechanic says replace it, we replace it.
    thanks. buong assembly kasi pinapalitan. from my experience sa casa, laging buo kung mag-replace kahit isang part lang may diperensya. don't know if I should just replace the fan and the motor is still okay, or if I should replace the whole assembly. how do I check?
    May 2004
    Usually sir yung motor po pinapalitan.. may mga ibang motor na pwede repair.. pero if I where you replace na lang ng fan motor... Sa sentra ko dati Series 4 I think 900, replacement lang, ang fan motor then ako na lang nag replace.. Cguro P200 lang labor ng ganoon or 250
  5. #5
    kung wala namang tama yung blades, just replace the motor and have it done outside. going prices ng bnew motors na japan is around 3-4k. Kung taiwan (circuit brand), between 1-2k depending on the model. Labor mura lang baka less than P300 lang yan.
    pwede ba sa urvan yung bnew japan motor for 3-4k. where can I buy one?
when to replace fan & motor assembly
