Results 1 to 8 of 8
    My car is a nissan lec-ps 2000 model. Malamig ang aircon pag umaandar ang car pero pag nakatigil during traffic di na malamig ang buga kaya pag matagal ang traffic mainit na sa loob ng car.
    Minsan maingay din ang tunog ng aircon ko. Need your expert advice, newbie lang po.
    Quote Originally Posted by ernanirivera View Post
    There is a chance your freon level is low. Also have the "filter" checked if it needs replacing.
    what kind of sound and where is it coming from?
    parang kuliglig and pakiramdam ko sa may compressor nanggagaling ang tunog. pero this doesnt happen always.
    Oct 2008
    Same problem po mga sir, pag nakahinto ako parang naka blower lang, pag umandar saka lalamig! Last Nov. pa po ko nagpalit ng New Evaporator, Freon,New Condenser. Kailangan ko na po ba mag Freon Charge??
    Sep 2004
    ^^^ Check the rad fans, baka hindi na malakas yung ikot.
    Happened to my Sentra before. Pag moving, ok ang aircon, pero pag traffic, mainit. Bumili lang ako ng surplus fan motor, problem solved.
    Aug 2009
    sir compressor na po problema nyan, loose compression na po, nakakapump lang sya ng maayos kung mataas rebolution ng makina, yung naririnig nyo naman na parang kuliglig yun yung valve sa loob ng compressor na di lumalapat dahilan para di makabomba ng wasto
    Feb 2009
    2 factors, your freon might be low or your drier and expansion vavle is stuck -up !
    if the sound is coming from the compressor , my advice is not to have it repair bec calsonic compressors are not meant for it , just buy a new one ! it will save you the repair cost !
    Tignan mo iyong auxillary fan mo baka hindi gumagana o mahina ang ikot dahil mahina na motor nito. Pa check mo na rin sa auto aircon shop kung may kilala ka. Wala naman bayad ang check up. para sigurado.
On and Off ang lamig ng aircon
