Results 1 to 13 of 13
    Dec 2009
    I'm planning on bringing my car to car aircon shop this coming weekend for annual cleaning. Sabay ko na din sana ipa-replace freon to 134a but I'm not sure kung kelangan. How do I know if my car is already using 134a? Is there a particular year model that started using it or my indicator ba sa engine bay or somewhere else in the car?
    My car is Altis 2003 J AT.
    Thanks in advance.
    Aug 2009
    Quote Originally Posted by samcoy View Post
    Thanks in advance.
    Alam ko hindi basta pinapalitan ng 134a ang ac mo, marami pang modification ang kailangan gawin sa cooling system mo. May sticker sa sa may engine bay kung 134a na ang ac mo.
    Aug 2010
    bro, 134a na yan, kasi 1996 up model ng sasakyan 134a na, alinsunod sa clean air act, depende nalang sa shop na gagawa kasi, nalamig din yan sa r-12 para malaki ang kita nila...
    Dec 2009
    Thanks mga bro sa reply. Tingnan ko sa engine bay ulit. Sinubukan ko na kasi hanapin pero wala ako makita saying like "134a".
    Sir banana, wala na pala ako dapat i-worry kaya lang puede pala nila palitan? Pano ko ba masisiguro na tamang freon ilalagay ng shop?
    Aug 2006
    Sa Altis, nasa engine bay pero nasa ilalim ng hood yung sticker sa bandang front.
    As early as 1994, some cars have been using R134A. If you can't find the sticker under the hood or around the engine bay, check the label on the compressor itself.
    AFAIK, if the installation is factory standard, the fittings are different from the R12 version to avoid loading the wrong type of refrigerant.
    Dec 2009
    Thanks Mile2 and ppcsurfr for sharing your knowledge. Appreciated! Tingnan ko this weekend.
    R134a na yan....
    May 2009
    Tignan mo kulay sa drier-filter.....kung green R-22, kung yellow R134a....pero as per refrigerant manufacturer pa rin ang color assignment.
    Dec 2009
    Ser Miked, san po located yung drier filter?
    Feb 2009
    Thanks in advance.
    1. the service fittings are going to be quick disconnect rather than screw on type schrader valve
    2. the service valves will be backwards in terms of size: R134a- the low side will have a smaller service fitting and the high side will have a smaller fitting
    3. if it is a thermal expansion valve type, usually will not have a sight glass
    4. it will have a lower suction side pressure
    5. the connections and flanges will use HBNR (green ) o-rings or seals
    6. should the evaporator develop a leak, it will smell like horse crap inside the cabin
    7. if you use a halide torch leak detector, the flame will not change even if there was a substantial leak
    8. by golly, if was produced later than 1994, it should be standard equipped with R134a
    9. it should already have a sticker that it uses R134a if it was original or it was retrofitted, any competent technician will already put a sticker on it stating it was retrofitted
    Dec 2009
    Tama kayo mga bro, 134a na. Tsaka tama si Mile2 nasa ilalim ng hood sa unahan yung sticker. Thanks ulit!
    Jun 2011
    Quote Originally Posted by abril View Post
    134A na yan. But if it's R12 you can convert it to 134A, it's not that complicated. You just need to replace the dryer, drain the oil, and if budget permits a new compressor doesn't matter if it's R12 or 134A spec.
How to determine if your car is already using 134a?
