Results 1 to 10 of 15
- Oct 2004
- 45
May 14th, 2006 04:48 PM #1What is the possible problem with this, when I turned ON the aircon and I step on the gas I hear an annoying sound. So I test without an aircon I step on the gas its normal. I suspect the problem with the pulley adjuster bearing so I replaced it, but still I hear the sound again. Is their a problem with the compressor? Does compressor has a bearing?
May 14th, 2006 04:53 PM #2
what sound? if it's like a squealing pig then probably belt ng compressor. Pag medyo rumbling-like noise na may grinding sound, malamang bearing.
but it's more difficult to tell WHICH bearing it is that's making the noise, baka paminsan kasi (like case ko dati), yung squeal happens when the AC compressor is on, but the noise came from the crankshaft pulley dahil di nya kaya na may load na extra...
Yes compressor has a bearing.
- Oct 2004
- 45
May 14th, 2006 04:59 PM #3sir, pagmalamig pa makina hindi ko pa maririnig. Bago timing belt, pulley bearing adjuster, tensioner bearing and oil seal. Ano kaya my cra?
- Oct 2004
- 45
May 14th, 2006 05:15 PM #4sir, hindi po yon squealing ng belt, parang ganoon my nag-rambling. Lalabas yon ingay pagmatagal umandar aircon. This only happens when I turned ON the aircon (dito wala pa ako maririnig) once I step on the gas hear the parang rumbling sound.
May 14th, 2006 05:21 PM #5
wala pong kinalaman ang timing belt... basically yung mga pulleys sa LABAS ng makina lang ang issue....
Mga makikita mo includes:
- Power steering
- Water Pump
- Alternator
- Main Crank pulley
- Compressor
- Idler Pulley
- yung mga iba may tension adjustment pulley...
Usually 2 lang belts nyan, yung isa nakakabit sa compressor at alternator, yung isa nakakabit sa P/S, waterpump.
- Oct 2004
- 45
May 14th, 2006 05:27 PM #6sir, bakit pag-naka-aircon at pag-inapakan lng yon gas sya maririnig at pagmainit n makina. kc pag wala aircon normal naman kahit apakan ko yon gas.
May 14th, 2006 05:30 PM #7
bossing, try mo alisin isa isa ang belt ,(compressor,power steering,alternator)
para malaman mo kung ano doon ang nag iingay
May 14th, 2006 08:27 PM #8
rambling sound? spell mo nga ehehehe! dug-dug-dug, tig-tig-tig, o kablag-kablag? hirap magdiagnose
kung naka-on lang ang aircon e sa aircon malamang. baka warped ang aircon clutch, or yung aircon compressor may internal damage na. try mo kaya alisin yung aircon compressor belt, then with key ON (engine off, ON mo lang ang accessories) try mo ikot ang compressor pulley trying with a/c switch ON and OFF. pag OFF ang a/c switch at magaspang ang takbo ng pulley then it's the clutch. pag a/c ON at may naramdaman kang mechanical defect, compressor. MAYBE!
May 14th, 2006 10:45 PM #9
Lumalamig pa ba a/c mo? Pwedeng sira ang internal bearing niya or yung shaft where the bearing rides on. Lalamig pa din a/c kahit sira mga ito.
Check the external items first.
- Oct 2004
- 45
May 15th, 2006 09:28 PM #10diagnose ko sa mechanic sabi nya, yon clutch sa compressor yon ma-ingay. Tinanong ko kung na gagawa, sabi ng mechanic hindi raw kc sealed daw yon. Palit daw ako ng bago compressor or surplus. Hindi na b talaga gagawa yon compressor clutch ?
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
