Originally Posted by
benchman
L300 gasoline '90 model user here, as what CivicVTi suggested.... yes, have the idle up device(actuator) checked if it's working.
if the actuator fails, posibleng mag-choke/mamatay nga yung makina pag nag-AC lalo na pag naka-idling sya dahil hindi na kaya ng makina yung load ng compressor with the aircon switched on.
nagpalit na po ako nito kailan lang, factory installed pa yung pinalitan kong actuator.
you can get this actuator at any decent suking auto supply around 150~250 pesos.
check your accelerator cable also, baka sticky na sya...apektado din yan pag gumagana na yung actuator/idle up system, you can almost feel the the idle up's slight pull at your accelerator pedal everytime na mag-eengage yung compressor pag naka-idle ka.
pinalitan ko na din 'tong sa amin. any replacement model will do also here.
hope it helps....
