Results 1 to 4 of 4
December 1st, 2007 01:29 PM #1
hi guys, ask ko lang what is the possible cause of my problem... kasi when the aircon kicks in i believe that the rpm normally goes up but also goes down easily, but mine however stays at 2k rpm longer than the usual and then the cold air from the aircon slowly diminsihes.... this event is most evident specially of traffic situations...
Help pls... thank you very much....
December 1st, 2007 07:05 PM #2
ipa adjust mo idling ng engine mo and yung idle up ng AC..dyan lang yun.
- Jul 2005
- 119
December 1st, 2007 10:31 PM #3check clearance of your comp. pulley and plate usually disengage when in long use
- Sep 2007
- 215
December 4th, 2007 07:58 PM #4try mo pa check yung thermoswitch mo sa aircon ... i think yun ang problem and i think its about time na pa linis mo yung aircon ng car mo ....
BANAWE AUTO SUPPLY
regy
They're hell-bent on sustainability kasi... even at the expense of a shorter lifespan from their...
BYD Philippines
