Results 1 to 2 of 2
    Mga Bossing,
    Ask lang ako, how much would an elbow joint connecting the upper radiator hose to the engine block? Meron na kasing butas ang elbow joint, and i've tried putting sealants pero tumatagas pa rin. I've already changed the upper radiator hose, and am planning to change the thermostat, isasabay ko na lang din ang elbow joint na to (medyo brittle na rin kasi).
    thanks and God bless.
    usually you buy a new elbow ... kasi wear and tear na yan ... because of rust ... sealant won't do kasi sooner or later the rust will eventually eat its way to the side of the sealant ...
    BANAWE AUTO SUPPLY
    regy
Elbow joint - Radiator/Thermostat
