Results 11 to 13 of 13
May 20th, 2004 01:58 PM #11
try mo pa check yung high pressure and low pressure hoses kasama na yung couplings nung 2. you should have brought it to a reliable ac shop kasi kung reliable yung napuntahan mo, baba lahat ng major parts ng a/c system mo, like condenser, evaporator and compressor pati yung low and high pressure hoses and they'll be checking it by submerging sa water to see if bubles are formed.
Paano ba na-check yung condenser mo binababa ba at kinapakapa lang for wet areas.
Yung iba kasi tamad na ac technician kakapain lang kung may basa sa condenser, e malapit yon sa radiator kaya if tuyo agad yung pinagsingawan.
May 20th, 2004 11:38 PM #12
thank you for your input sir. binaba po nila yung condenser and evaporator kinabit nila sa compressor and then nilublob sa tubig for bubbles kaso wala po kaming nakita eh.
di na nila binaba yung compressor ko saka yung mga hose. san po kaya magandang ipacheck yung aircon?
- May 2004
- 5
May 23rd, 2004 02:14 AM #13Well, for sure, you have a small leak!
Small leaks are very hard to find.. techniciasns should use a "freon dectector" I call it a "sniffer".
Its a device that senses the freon.... I makes a beeping (beep, beep, beep) noise and when it senses the freon, it makes a straight beep noise (beeeeeeeeep)!
That device is only for R-134a type of coolant though!
They can also use a dye...If you have a leak, it should be visible with a black light! You put it in the AC system and and let the AC run for a few minutes. ..then you turn off the light and look for the leak with a black light!
Check your compressor to see if the clutch kicks in...
Kung di mo afford ang Ferrari Purosangue , dito kana sa Xiaomi YU7:grin: - - - - - - -...
Xiaomi E-Car
