Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Feb 2003
    Yung aircon ko po nagloloko pag mainit... Naririnig ko yung 'clicking' sound pauulit ulit ng mabilis... parang namamatay at bumubukas yung aircon ng mabilis... pag nangyayari to nde masyadong lumalamig yung aircon... pero after a while titigil na sya and lalamig na... napalitan na yung vacuum advancer pero ganon pa rin...
    Salamat!
    Have your radiator and cooling system checked for possible leaks. Also have your A/C system checked.
    baka sira ang thermostat .... it is the one sending the on-off signal to the compressor....pagmadumi na ang evaporator minsan ganun din ang sintomas ng problem (nag-ice na ang evaporator).
    kung kapaplit lang ng vacuum advancer, baka pwede mo pang ibalik sa shop baka under warranty pa, mas maganda matingnan agad.8)
    Dec 2002
    Kaiser,
    The system could be under high pressure causing the compressor to cut on and off. Check the following:
    1) aircon aux fan- if this is slow or busted then system is overheating.
    2) lack of freon or too much freon- watch the glass window atop the aircon drier, should show bubbles when you switch on, then should disappear, then reappear when you switch off. If you see a constant stream of bubbles then you lack freon but if no bubbles at all, then too much freon.
    3) Change the drier if they find a leak or clean the system but don't change the expansion valve, unless busted, since these can last the life of a car.
    Tell us when you finally find the problem!:wink:
    crv ko dati ganyan, sira lang pala aux fan. umiikod naman yung aux fan pero walang hangin.
    Signature
    Dec 2002
    palinis mo na din baka madumi lang or check mo rin ang mga wirings
    dude ganyan problema ko sa aircon, pag on mo may tunog parang on and off din. nawala at humihina ang lamig. hindi ko alam ang tawag pero nakita ko yung ginawa yung part ng aircon sa ilalim na may belt yung iniikutan ng belt sira na yung ipen kaya minsan umiikot minsan hindi hindi na naglalapat kaya may tunog. sabi wala wala atang part na nabibili para dun buo mo na sya bibilin. ang ginawa binaklas at naghanap ng pede ipalit dun sa aprt na sira galing sa galant swak naman at nawala yung tunog pag on mo ng aircon at tuloy tuloy na yung lamig.
    last saturday lang ginawa ang total bill ko inabot lang ng 900 kasama na karga ng freon, cleanng, o-ring at filter drier nag tip na din ako ng 100 kasi sobra sulit ng gawa at talagang tutok sila sa customer.
    pa tsek mo din yung drier pag inalog at parang may tunog na papalitan mo na.
    PM mo si Otep para sa exact location ng shop...:D
    Mar 2003
    try mo ring pa check yung soleniod switch
    baka yon clutch ng compressor hindi na kumakapit.
Aircon goes crazy pag mainit
